2JZgte manifolds
2JZgte manifolds
Postby Stott69 » Thu Aug 02, 2012 9:26 pm
Looking at changing the exhaust manifold on the Aristo. Currently running a twin to single adapter. So what are people running or what would you suggest?
Stott69
Postby Dell'Orto » Thu Aug 02, 2012 9:52 pm
Maybe PM ActionDan or evil_si. Don't be a jew and buy something cheap, it'll $&#$% out quickly.
Postby Stott69 » Thu Aug 02, 2012 10:03 pm
Thats why Im posting here, to find whos found what, with bang for buck
Stott69
Postby Bazda » Thu Aug 02, 2012 10:39 pm
We can do the Sinco manifolds for $950+gst
10 year no crack warranty as well.
Postby MrOizo » Fri Aug 03, 2012 2:37 am
If you have the monies....
http://garagewhifbitz.co.uk/
MrOizo
Toyspeed Legend
Postby Quint » Fri Aug 03, 2012 10:20 am
Bazda wrote:Image
hawt!
Quint
Postby Lith » Fri Aug 03, 2012 10:57 am
Yeah I'd go with Sinco, definitely. Local, quality etc.
2007 Mazdaspeed Axela
Lith
Postby 92mr2paddy » Sat Aug 04, 2012 5:16 pm
+1 for sinco, been running one for 3 years now and its perfect in everyway!! im getting one for my 2jz made soon, he does great work, dont be cheap you always get what you pay,
92mr2paddy
Postby Stott69 » Sat Aug 04, 2012 5:48 pm
Does anyone know about these ones ?
http://www.trademe.co.nz/Browse/Listing ... =500189001
Stott69
Postby MrOizo » Sat Aug 04, 2012 5:56 pm
Stott69 wrote:Does anyone know about these ones ?
That looks like the eBay ones but coated!
http://www.ebay.com/itm/93-98-Toyota-Su ... 99&vxp=mtr
MrOizo
Toyspeed Legend
Postby Mr Ree » Sat Aug 04, 2012 6:02 pm
Yeah it will be pretty much identical.
Normally, the only difference with the ebay spec chinese hks knock offs, is how much slag is left in the collector, and how warped the flanges are.
If you have access to a die grinder to tidy up the welding slag, and know somebody who can resurface the flanges for a good price, then they will be fine.
wak thud gush!
Mr Ree
Postby Girvs » Sun Aug 05, 2012 2:21 pm
I'm considering a PHR manifold. Far from cheap, but lifetime crack free warranty.
But as mentioned above, SINCO is good bang for buck and proven quality.
Girvs
Postby 92mr2paddy » Sun Aug 05, 2012 6:04 pm
wouldnt go for the cheap trademe ones, they will be same as ebay ones ssautochrome rubbish, no wastegate (unless fake) has the 4bolt flanges anymore so thats always an easy way to spot the cheap n nasty, as for cleaning up the slag etc doesnt always work i had a cheap chinese manifold few years back and it couldnt be tunned as it boost spiked all over the place as where the collector and wastegate port is badly designed.
got a sinco one made and gained 30kw with 3-4pound less boost,
92mr2paddy
Postby Makaveli » Sun Aug 05, 2012 6:05 pm
Why is everyone going with steam pipe? I think it's too heavy and over the top. What's wrong with good old stainless steel?
Makaveli
Postby Dell'Orto » Sun Aug 05, 2012 6:21 pm
Steam pipe never breaks
Postby Stott69 » Sun Aug 05, 2012 6:54 pm
Will have to save some more unless someone has a second hand one for me?
Stott69
Postby Mr Ree » Sun Aug 05, 2012 7:04 pm
92mr2paddy wrote:wouldnt go for the cheap trademe ones, they will be same as ebay ones ssautochrome rubbish, no wastegate (unless fake) has the 4bolt flanges anymore so thats always an easy way to spot the cheap n nasty, as for cleaning up the slag etc doesnt always work i had a cheap chinese manifold few years back and it couldnt be tunned as it boost spiked all over the place as where the collector and wastegate port is badly designed.
Yep, unfortunately thats the risk you take when buying ebay spec stuff, as its so inconsistent. Somebody might get one that was built on a monday morning, and someone else, from a friday afternoon (although we all know these factories run 24/7) But you get my point lol
I wouldnt recommend one to somebody with no ability to tidy them up either.
You got good results from you sinco upgrade :) Its possible the wastegate ports in the collector were virtually blocked up, I know mine certainly were before they met a carbide tip at 100,000rpm lol
wak thud gush!
Mr Ree
Postby Makaveli » Sun Aug 05, 2012 7:15 pm
Inconel Formula 1 Manifold FTW :P
Makaveli
Postby Dell'Orto » Sun Aug 05, 2012 7:32 pm
Probably costs as much as all the cars on this forum though :lol:
Scott - good idea. Though really, you should asshole that turbo and go back to the stockers.
Postby BlakeNZ » Sun Aug 05, 2012 9:06 pm
Why do you want to change from your cast factory one, merged together into one?
I bet your car spools well. and your current set up won't crack.
Also, the factory cast one is the only manifold that has all six ports running in the same direction(angle) as the six exhaust ports on the JZ heads. i.e. 4 on angles, 2 straight.
PORT THAT SUCKER!!!
BlakeNZ
