3sgte Oil return pipe
Postby BR0Z » Thu Sep 20, 2012 1:57 pm
Hi - need to know lenght & diameter of rubber pipe so as to replace, cheers
Oldie but goodie
Mark Bros
91 GT FOUR RC x 3 1 Red (mine) Daniel - 2 White - 1 damaged & for sale =(
May the FOURce be with you
http://toyspeed.blakjak.net/profiles/profile.php?id=244
BR0Z
Postby Quint » Thu Sep 20, 2012 4:52 pm
for the turbos? arn't they hard lines?
Quint
Postby BR0Z » Thu Sep 20, 2012 4:54 pm
Hi most of the pipe is hard line but with a short 'rubber' section where it clamps onto sump. Cheers
Oldie but goodie
Mark Bros
BR0Z
Postby Dell'Orto » Thu Sep 20, 2012 6:40 pm
19mm/ 3/4". Length on Gen 3 is maybe 50mm, Gen 2 is quite a bit longer and has a funny curve.
Postby BR0Z » Fri Sep 21, 2012 1:37 pm
Cheers =)
Oldie but goodie
Mark Bros
BR0Z
Postby gt4dude » Fri Sep 21, 2012 2:56 pm
thats what mine measured, for st205, i sent a picture of it to dan he said his was smaller?
OIL RETURN PIPE THAT IS
セリカGT-FOUR ST205 中期型 (Chuuki)
200AWKW / 370NM
gt4dude
Postby BR0Z » Fri Sep 21, 2012 3:11 pm
Cheers Mike, I think Dan has sorted something out - he went out to car last w/end & discovered it's a bit mouldy inside so has to sort that as well as other things - soon he should have it back up and running & then he can change rego to his name & then get the BROZJR plates =)
Oldie but goodie
Mark Bros
BR0Z
Users browsing this forum: Bing [Bot], Google [Bot] and 25 guests
