3sgte Oil return pipe
Hi - need to know lenght & diameter of rubber pipe so as to replace, cheers
Oldie but goodie
Mark Bros
91 GT FOUR RC x 3 1 Red (mine) Daniel - 2 White - 1 damaged & for sale =(
May the FOURce be with you
http://toyspeed.blakjak.net/profiles/profile.php?id=244
Mark Bros
Hi most of the pipe is hard line but with a short 'rubber' section where it clamps onto sump. Cheers
Oldie but goodie
Mark Bros
Mark Bros
- Dell'Orto
- ** Moderator **
19mm/ 3/4". Length on Gen 3 is maybe 50mm, Gen 2 is quite a bit longer and has a funny curve.
Cheers =)
Oldie but goodie
Mark Bros
Mark Bros
Cheers Mike, I think Dan has sorted something out - he went out to car last w/end & discovered it's a bit mouldy inside so has to sort that as well as other things - soon he should have it back up and running & then he can change rego to his name & then get the BROZJR plates =)
Oldie but goodie
Mark Bros
Mark Bros
