ae101 e58 lsd gearbox oil
Postby mega4a » Sun Oct 07, 2012 8:24 pm
mega4a
Postby touge_ae101 » Sun Oct 07, 2012 9:50 pm
He doesn't know shit. 75-90 syntrax or trd lsd oil. pretty sure trd oil just got discontinued but its the same as the motul gbox oil..
trd prob isn't necessary though not a clutch type diff..
touge_ae101
Postby AE82 FXGT » Mon Oct 08, 2012 6:12 pm
Yeah I ran syntrax in mine, went sweet as, felt nice.
I've heard of running ATF in manual transmissions before, but not on one of these.
AE82 FXGT
Postby Bazda » Wed Oct 10, 2012 6:50 pm
Penrite sin 75 is the best option.
Motul gear FF but its quite $
Postby mega4a » Mon Oct 15, 2012 2:52 pm
he also said synthetic was no good and will eventually polish my syncros.
put some 80-90 gear oil in and it seems to be abit whining so im guessing wrong oil
also put a heavy duty clutch from exedy in and it slips WTF!! i did run it in btw.
mega4a
Postby Bazda » Mon Oct 15, 2012 3:01 pm
mega4a wrote:he also said synthetic was no good and will eventually polish my syncros.
Who is he?
The above oils i've suggested are race proven and work very well in these boxes.
Remember when running a viscous LSD, if you run an oil too thin it can get very hot, meaning the viscous LSD wont work as well.
I found this out when I ran a viscous lsd for a little bit until I stripped 2nd gear.
Both the Sin 75 and Motul FF are designed for LSD boxes with Syncros.
Postby Mr Revhead » Mon Oct 15, 2012 3:20 pm
Are the Toyota viscous lsds not sealed. Pretty sure they are. So the oil you run will have no bearing on LSD performance.
So, you also don't need LSD oil.
Postby Bazda » Mon Oct 15, 2012 3:27 pm
Mr Revhead wrote:Are the Toyota viscous lsds not sealed. Pretty sure they are. So the oil you run will have no bearing on LSD performance.
But if the oil around it gets hot the viscous lsd internals get hotter.
Postby Mr Revhead » Mon Oct 15, 2012 4:39 pm
Didn't catch your use of the word "hot" in your previous post :wink: :oops:
Postby mega4a » Mon Oct 15, 2012 5:41 pm
its not viscus lsd its mechanical
mega4a
Postby mega4a » Mon Oct 15, 2012 6:10 pm
mega4a
Postby Mr Revhead » Mon Oct 15, 2012 6:16 pm
What brand is it? Factory ones are viscous. If its mechanical what do the makers specify?
Postby mega4a » Mon Oct 15, 2012 6:27 pm
Mr Revhead wrote:What brand is it? Factory ones are viscous. If its mechanical what do the makers specify?
its from trademe. i think its from an ae101 4agze levin but wouldnt have a clue..
it has a pin in the diff but also my 4afe c52 had one.
mega4a
Postby mega4a » Mon Oct 15, 2012 6:38 pm
i thought all super charged lsd where mechanical?
i thought only 20v blacktop and silver top came with viscus?
mega4a
Postby AE82 FXGT » Mon Oct 15, 2012 7:08 pm
no, ae101 gtz gearboxes are factory viscous lsd.
AE82 FXGT
Postby sergei » Mon Oct 15, 2012 7:23 pm
Mechanical could be interpreted as torsen (helical) or clutch type.
The BZR comes with torsen type. Torsen behaves like open diff when the car is off the ground.
The helical LSD can be spotted via the holes in the diff it self (the helical and odd straight cut gears are visible).
I believe the AE101 GTZ diff is of viscous type.
Postby tsoob » Mon Oct 15, 2012 10:49 pm
I run the redline blue stuff.. $&#$% me its $$ tho. Get Bazz's oil its cheaper.
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
WHEELS, TYRES & SUSPENSION!
www.platinumwheels.co.nz
tsoob
Postby Bazda » Tue Oct 16, 2012 12:00 am
ae101 gtz are all viscous LSD.
If you look down the passengers side diff hole you will see an extra spline which is separate to the diff spline, that drives the viscous. It also has a hex bar in the centre.
This also meaning the box takes diff shape shafts and has to use the AE101 gtz shafts. Non LSD ones wont work.
C series boxes have the hex bar but it doesnt mean anything, its still an open diff.
Some late model AE92s came with the Mechanical LSDs (TRD). Very rare to find.
Postby mega4a » Tue Oct 16, 2012 4:55 pm
lol i guess ill just have to save for a trd diff!!
put ATF in today runs mint no noise changes perfect! i think ATF is the go!
mega4a
Postby mega4a » Tue Oct 16, 2012 5:00 pm
and the fella who recommended it is 60 years old and races 4agze for god nos how long has 4 of them and he is steven from Glen Eden mechanical he rebuilds the gearboxes too! he says synthtic will polish your syncros and eventually ruin them and redline stuff is too thick as well.
and atf is the go!
mega4a
Users browsing this forum: Google [Bot] and 17 guests
