Gen 1 and Gen 2 MR2 3SGTE interchangeability
Postby sunskreens » Sun Oct 14, 2012 1:51 pm
Hey team quick question, are gen1 and gen 2 ignition systems intechangeable? Ie the whole dizzy, cap, rotor and all, and leads between Gen 1 and Gen 2 GT and GTS? Just trying to troubleshoot someones car atm. Thanks in advance!
If it helps, gonna try and use Gen 1 gear on Gen 2 engine to see if ignition on gen 2 is poked
sunskreens
Postby Grrrrrrr! » Sun Oct 14, 2012 2:21 pm
Both are gen2 3SGTE engines, so shouldn't be a problem. Coil and igniter might be different, but swap them as a pair and you should be fine so long as the connectors are the same
Grrrrrrr!
Postby sunskreens » Sun Oct 14, 2012 7:07 pm
Should have been a bit clearer. We are gonna try and use my gen 1 stuff from my GT, into a mates 93 GTS. Mainly just rotor, dizzy cap and leads to check and see if it improves the situation.
sunskreens
Postby Grrrrrrr! » Sun Oct 14, 2012 7:14 pm
Yep, so both gen 2 3sgte motors. Unless its a late 93 Gen3 (ie, the facelift model) sw20, in which case its a gen3 3sgte motor, and then they probably wont be compatible.
The sw20 never got the gen1 3sgte, only the st165 got that one i think.
Grrrrrrr!
Postby sunskreens » Sun Oct 14, 2012 7:25 pm
<3 Thanks man. Gonna try them tomorrow night. Just as a side note, the GTS (93) has clips for the leads, whereas the TGP new for the GT (90) has just plug in leads. Will it make a difference? Im assuming rotor will also have 2 screws holding it in, or will I have to play discover the similarities? Lol
sunskreens
Postby Alex B » Sun Oct 14, 2012 7:32 pm
You sure the 93 is a gen 2, pretty sure that was gen 3 swap over year.
Postby sunskreens » Sun Oct 14, 2012 7:39 pm
Still running AFM looks to be a pfl 93
sunskreens
Postby Alex B » Sun Oct 14, 2012 7:40 pm
Sounds like it :)
Postby sunskreens » Sun Oct 14, 2012 7:42 pm
Saweet! Thanks team. Will give it a go tomorrow <3 Toyota lego
sunskreens
Postby Al » Sun Oct 14, 2012 8:29 pm
The leads attach differently to the cap. The 89-91 are friction fit, wheras the 92-10.93 have a clip like the coil lead.
Al
Postby sunskreens » Sun Oct 14, 2012 8:36 pm
Yup, but if I were to just swap it over to test, I would be swapping the whole cap and all the leads too, so should be hunky dory right?
sunskreens
Postby sunskreens » Mon Oct 15, 2012 7:51 pm
So as it turns out, the coil point is also different between Gen 1 and Gen 2 3S. Coil point for Gen 1 is much wider than coil point for Gen 2. Gen 2 tapers in. I had to squeeze the point with some pliers gently and I can confirm you can swap em all round. Just need to mess about a bit with the widths of the coil lead. Hope this may help!
sunskreens
