hiace van steering wheel shudder under braking
Postby 92mr2paddy » Sun Jan 20, 2013 9:10 pm
just wana find out what could cause this before i take it to alignment shop/toyota or whatever,
when you brake lightly or hard doesnt matter the steering wheel will shudder lightly, will shudder harder the more downhill your going, like bombays or kaimais is shudders like a b*tch,
the braking isnt affected it seems like it has no problems stopping and it doesnt pull to the side or anything like that, alignment seems ok no odd wear on any of the tires and it doesnt pull to the side.
van isnt lowered and on standy rims, '05 model new shape if that helps, thanks guys
92mr2paddy
Postby 85AW20v » Sun Jan 20, 2013 9:17 pm
Probably warped discs. Getting them skimmed at a brake shop might fix it otherwise if they're too worn, new discs will be needed. Make sure the wheel nuts are torqued to the correct spec too as that can help stop the warping in the first place.
See ya
Simon
85 MR2 20v
85AW20v
Postby Bling » Sun Jan 20, 2013 9:57 pm
Have the wheels come off recently?
Postby Crucible » Mon Jan 21, 2013 12:33 am
Front rotors, machine or replace
Crucible
Real Life Mechanic
Postby 92mr2paddy » Mon Jan 21, 2013 6:42 am
nah wheels havent come off since ive had it but will check the discs,
92mr2paddy
Postby solitaire » Sun Jan 27, 2013 10:22 pm
I had this on the wifes hilux, shuddering going downhill.
Got the disks skimmed and it got a little bit better but got bad again within a few months.
Then replaced with toyota disks and pads and it's been sweet for months.
AE92, KZJ120, KDJ120
solitaire
Postby AE82 FXGT » Mon Jan 28, 2013 6:08 pm
solitaire wrote:I had this on the wifes hilux, shuddering going downhill.
When they get skimmed they are made thinner so they become more susceptible to becoming warped.
New thick rotors (especially genuine) should be good for ages.
AE82 FXGT
Users browsing this forum: Google [Bot] and 27 guests
