Airlock in fuel pressure gauge line.
Postby Grrrrrrr! » Thu Feb 21, 2013 7:11 pm
Just realised that there is going to be no way to bleed air out of the line going to the sender for the fuel pressure gauge, I can't really see how it'll cause any problems, but just wanted to check before I go bolt it in. Sender is at the end of 200mm or so of braided line*.
So, is it likely to cause issues or shouldi just bolt it in and go for it.
*hmmm,, second question, is braided brake line okay for fuel, or should I go throw this back at the monkey who made it before I end up spraying petrol all through the engine bay when it fails?
Grrrrrrr!
Postby Crucible » Thu Feb 21, 2013 11:00 pm
Youll be right.
Crucible
Real Life Mechanic
Postby Grrrrrrr! » Thu Feb 21, 2013 11:02 pm
Nope, petrol. fitted it up, and the gauge reads some number that might be right. I think i'll just run with it for now, bigger fish to fry, like the 60psi base pressure!
Grrrrrrr!
Postby Crucible » Thu Feb 21, 2013 11:11 pm
Grrrrrrr! wrote:Nope, petrol. fitted it up, and the gauge reads some number that might be right. I think i'll just run with it for now, bigger fish to fry, like the 60psi base pressure!
Im not familiar with your project . 60psi sounds high.
Crucible
Real Life Mechanic
Re: Airlock in fuel pressure gauge line.
Postby allencr » Fri Feb 22, 2013 6:02 am
Grrrrrrr! wrote: ...is braided brake line okay for fuel,
'braided line' doesn't mean anything, only the manufacturers specs for that hose's model number concerning compatibility with different fluids, its working pressure & burst strength.
That said, it is very unlikely that you'd be able to find any line that wasn't petrol friendly & easily able to handle 60psi.
Any air will compress, no problem, it just slows the gauge's reaction a bit.
allencr
Users browsing this forum: No registered users and 27 guests
