Funcargo engine check light - jumper for code?
Postby Pnut » Thu Mar 07, 2013 8:07 am
My inlaws have a Funcargo, the engine check light came on recently so I would like to find out the code it is throwing. Does anyone know if you can jump 2 pins on the diagnostic plug to get the code on these? If so which ones?
Are these OBD2 compliant?
I'll try being nicer if you'll try being smarter
Pnut
Postby Dell'Orto » Thu Mar 07, 2013 6:24 pm
Pretty sure they are OBD2
Postby Crucible » Thu Mar 07, 2013 7:07 pm
1996 on are OBD2. Youll need a scan tool to retrieve codes, older nissans you could bridge terminal under steering wheel and read codes by check lamp.
Crucible
Real Life Mechanic
Postby Pnut » Sat Mar 09, 2013 7:55 pm
so its not like the altezza i had where you could bridge a couple of the terminals on the OBD2 port to make the check light flash a code? :?
Pnut
Postby sergei » Sat Mar 09, 2013 8:06 pm
Pnut wrote:so its not like the altezza i had where you could bridge a couple of the terminals on the OBD2 port to make the check light flash a code? :?
I'm pretty sure you can still do that.
Postby RS13 » Sat Mar 09, 2013 8:32 pm
If it has TE1 and E1 terminals on the connector, I wouldn't see how it was any different to any other Toyota.
RS13
Postby Crucible » Sat Mar 09, 2013 11:20 pm
What year altezza?
Im not entirely sure but older OBD1 vehicles have a two digit numbered code where as OBD2 start with a letter. POxxx for generic codes and P1xxx for OEM specific so i wouldnt think you could get that from a flashing check lamp.
My guess would be that you will need a scan tool.
Crucible
Real Life Mechanic
Postby rollaholic » Sun Mar 10, 2013 8:11 am
seem to recall some of that stuff in the middle doing both, you'll get a more detailed code from a scanner but flash thing still works
Postby Pnut » Tue Mar 12, 2013 9:59 pm
thanks for the replies. I have been trying to use a cheaper OBD2 scanner but unfortunately so far we havent been able to get it to communicate with the ecu. Seems as it is a 2000 model it might be at that in between phase where they werent using the OBD2 protocols. :roll:
Does anyone know of any scan software to try with USB connector that might work with that vintage toymota's? :)
Pnut
Postby sergei » Wed Mar 13, 2013 8:39 am
Pnut wrote:thanks for the replies. I have been trying to use a cheaper OBD2 scanner but unfortunately so far we havent been able to get it to communicate with the ecu. Seems as it is a 2000 model it might be at that in between phase where they werent using the OBD2 protocols. :roll:
Well if it is Toyota Proprietary then you will need toyota tool or a paper clip.
http://www.obd-obdii.com/download/Lexus%20Toyota/Toyota%20Corolla%20ZZE122R%20DTC%20Check.pdf
Basically it is not quite OBD2, so jump pin 4 and 13 as per document.
Postby Pnut » Wed Mar 13, 2013 10:18 pm
ok cool thanks guys. Gave that a whirl and it flashed up a 2 and a 5, i guess that is 25? :D
Any idea what that relates to? (i am guessing it is probably o2 sensor, but want to confirm.
Interestingly the engine check light isn't coming on any more, but the code will still flash when i jump those pins. :?
Pnut
Postby sergei » Thu Mar 14, 2013 8:31 am
Pnut wrote:ok cool thanks guys. Gave that a whirl and it flashed up a 2 and a 5, i guess that is 25? :D
viewtopic.php?t=35814
25 Air-Fuel Ratio Lean Malfunction
Diagnosis
* When air-fuel ratio feedback compensation value or adaptive control value continues at the upper(lean) or lower(rich) limit renewed for a certain period of time.
* When air-fuel ration feedback compensation value or adaptive control value feedback frequency is abnormally high during feedback condition.
* When marked variation is detected in engine revolutions for each cylinder during idle switch on and feedback condition.
Trouble Area
* Injector circuit
* Injector
* Fuel line pressure
* Air flow meter
* Air intake system
* Oxygen sensor circuit
* Oxygen sensor
* Ignition system
* Water temp sensor
* ECU
I would measure the voltage on OX sensor, and clean the AFM, as start.
Postby Pnut » Thu Mar 14, 2013 9:06 am
Awesome thanks sergei, thats what i had thought to but glad for the confirmation!
спасибо :D
Pnut
Postby Crucible » Thu Mar 14, 2013 6:59 pm
+2
Crucible
Real Life Mechanic
Users browsing this forum: Bing [Bot], Google [Bot] and 39 guests
