BZ Touring. Manual conv. Pulling to the left under acc. help
Postby RobertC » Sun May 12, 2013 11:37 pm
So just finished putting the car back together after replacing the auto box with a c56 lsd box.
Car is a 97 Corolla BZ Touring. Still running the auto ecu (how do i get rid of the lashing OD light?)
Car had some 130,000km new box 150,000km.
Just took it for a test drive and its wanting to dive for the ditch if i accelerate even just mildly.
The car had a wheel alignment 2 weeks ago.
Any ideas? :cry:
MRAE111 wrote:ok thanks guys but wen u dont have trmpets i think the air flow quickeer into the throttle bodies
RobertC
Postby siren676 » Mon May 13, 2013 12:00 am
Torque steer or dud engine/gearbox mount?
siren676
Postby Mr Revhead » Mon May 13, 2013 12:12 am
Did you undo the tie rods at all?
Postby RobertC » Mon May 13, 2013 12:51 am
The only suspension/steering thing undone was the lca to ball joint nuts and bolts so I could remove the axles.
Engine mount wise:
Drivers side = no change
Front = Used the auto one
Rear = Bracket off a 6 speed manual. Mount auto one.
Passengers side. = Modified 6 speed bracket mounted to auto mount.
The gearbox maybe sounds a bit noisy.
Just checked Tyre pressures all fine.
All wheels spin reasonably freely.
The pulling is to the point that at half throttle slowly taking off in first gear if I let go of the wheel I would be in the ditch in about 2 car lengths.
RobertC
Postby iOnic » Mon May 13, 2013 7:52 am
Does it only do it under power? Or will it do it if you're coasting in neutral and let go if the wheel?
Sounds to me like your wheel alignment is out.
Postby RobertC » Mon May 13, 2013 5:34 pm
Car has just been at the suspension shop for the afternoon.
They can't find anything wrong with the suspension.
Driving on a straight piece of road @ 100 kph.
In gear coasting it pulls to the left a little bit.
Braking and in gear about the same.
Accelerating it pulls hard to the left.
With the clutch in it tracks perfectly straight. Braking with the clutch in still goes straight.
Drivers side engine mount is no been changed. Front and back mounts are correct as per toyo diy.
Passengers side mount was modified as a factory mount does not exist for a 5 speed in a post 97.6 corolla.
RobertC
Postby Mr Revhead » Mon May 13, 2013 5:37 pm
When you swapped the driveshafts did you put the drivers side drive shaft support back on?
Postby RobertC » Mon May 13, 2013 6:10 pm
Mr Revhead wrote:When you swapped the driveshafts did you put the drivers side drive shaft support back on?
yeah, had plenty of fun with that. Originally tried to install the drive shaft with the auto bracet before realizing it wouldn't go in because I needed a manual bearing hanger bracket which is now installed.
RobertC
Postby Mr Revhead » Mon May 13, 2013 6:41 pm
They are fun....
Sounds like its box or diff then. Time to put it on stands and turn some wheels I guess
Postby BlakeNZ » Mon May 13, 2013 9:05 pm
pop the bonnet and rev the motor. What way is the motor twisting? Is the passenger side twisting forwards more than the drivers side?
BlakeNZ
Postby RobertC » Mon May 13, 2013 10:26 pm
BlakeNZ wrote:pop the bonnet and rev the motor. What way is the motor twisting? Is the passenger side twisting forwards more than the drivers side?
It just slightly rocks back on forwards. Looking down is does not twist.
RobertC
Postby RobertC » Mon May 13, 2013 10:33 pm
Where do I go from here? Do it try another gearbox?
Could it be axle related?
Could the engine mount I had to modify be causing all this? If the passengers side mount is too high or to low would this happen?
Looking up from the bottom of the car should the passengers side drive shaft be inline to the drivers side half shaft? (currently it points forwards a bit.)
Also did a skid in the paddock and it left two solid lines so both wheels are definitely being driven.
RobertC
Postby RobertC » Mon May 13, 2013 11:40 pm
I've just purchased another gearbox I'll put it in on the weekend and see if that solves the problem.
RobertC
Postby BlakeNZ » Tue May 14, 2013 10:09 pm
answer this. What would you need to modify to get the passenger side half shaft going straight out the wheel, rather than angling forward slightly?
BlakeNZ
Postby sergei » Tue May 14, 2013 11:05 pm
It maybe due to bracket/mount mismatch, specifically the auto mount on C160 bracket.
I know for a fact that C160 plate/bracket does not fit C5X. The bolt holes need to be redrilled in different location and some welding could be involved. Although I did the opposite (replaced C52 with C160), it still applies.
Have you tried using the mount that the C56 came with?
You can raid any AE101 for the C5X mount from pickapart, much cheaper than buying new gearbox.
Postby RobertC » Wed May 15, 2013 12:33 am
BlakeNZ wrote:answer this. What would you need to modify to get the passenger side half shaft going straight out the wheel, rather than angling forward slightly?
The mount would have to move back close to an inch. But this is impossible as with the front and rear mounts it can't really be rotated. (The front and rear mounts are 1oo% correct.)
I removed the passengers side engine mount and connected the mount bracket to a chain hanging from above so there would be nothing stopping if from moving back and forwards. It stayed where it was.
The only movement really possible is up and down slightly at the gearbox end. Which i tried, changed toe mount to raise the gearbox end up by 10mm and it made no difference.
RobertC
Postby RobertC » Wed May 15, 2013 1:05 am
sergei wrote:It maybe due to bracket/mount mismatch, specifically the auto mount on C160 bracket.
These mounts from a post 97.04 fz or xz levin should bolt up. (5 speed c series gearbox and would have the mount that bolts to the chassis rail)
Currently the mount i'm using is (this bit bolts to the chassis rail)
And this (original auto mount) Bolted to a re-drilled 6 speed bracket.
(this)
RobertC
Postby RobertC » Fri May 17, 2013 11:12 pm
Got a new engine mount and bracket from the wreckers and now its all 100% bolt up. The new mount dropped the gearbox end about 20mm.
All the bolts now slide through the holes with ease.
I have taken measurements of a car with the same motor and everything matches perfectly. Drive shafts of the car I compared too are at the same slight angle.
But the car still won't drive straight :evil:
RobertC
Postby sergei » Sat May 18, 2013 11:37 am
RobertC wrote:Got a new engine mount and bracket from the wreckers and now its all 100% bolt up. The new mount dropped the gearbox end about 20mm.
Stab in the dark: perhaps one of the CV is seizing?
Postby 85AW20v » Sat May 18, 2013 2:01 pm
Or maybe the LSD in the C56 box is toast which might only show up on a surface with good traction as opposed to a paddock with no traction?
See ya
Simon
85 MR2 20v
85AW20v
Users browsing this forum: Bing [Bot] and 15 guests
