4AGE Bluetop
4AGE Bluetop
Postby spoonza6 » Sat Jun 01, 2013 2:25 pm
Just bought me an AE82 GT and come across an annoying problem
Up to when the water temp is half way, car runs fine
Once it's warmed up and running for a while whenever I slow down to stop it dies
Revs drop n it cuts out...
Where do I start?
spoonza6
Postby Lloyd » Sat Jun 01, 2013 2:49 pm
How high does it idle when it's dead cold?
Postby spoonza6 » Sat Jun 01, 2013 3:00 pm
Around 2000rpm
spoonza6
Postby malc » Sat Jun 01, 2013 3:44 pm
All your vacuum lines connected up properly? could be something to do with the dash pot and throttle stop.
malc
Postby touge_ae101 » Sat Jun 01, 2013 11:45 pm
Ecu water temp sensor + vacuum lines. replace. job done.
touge_ae101
Postby Vertigo » Sun Jun 02, 2013 12:14 pm
Yea I used to get big rpm blips with my BHG, the water temp sensor was getting bubbles of exhaust gas on it and freaking out. Look there.
TVIS just kicked in, yo!
Vertigo
Postby spoonza6 » Sun Jun 02, 2013 4:10 pm
Vertigo wrote:Yea I used to get big rpm blips with my BHG, the water temp sensor was getting bubbles of exhaust gas on it and freaking out. Look there.
Ok so your car would cut out as you slowed down to a stop??
spoonza6
Postby xsspeed » Sun Jun 02, 2013 4:31 pm
Check other things before assuming bhg
if you leave it idling so it gets hot do the revs drop to around 900 or so or does it stall once the Cold injector drops out
