Just installed these the other week and I'm having trouble fixing the spring binding/pop. When I turn the wheel (car not jacked up) the pillow ball doesn't move so its turning the shaft inside the shock body and it binds the spring. I am right in thinking that when you steer it's meant to rotate on the pillow ball? I sprayed some crc on it gave it a good wiggle but made no difference still tight.
