Wheel studs (because everyone loves pictures)....
Postby jondee86 » Sat Aug 03, 2013 7:48 pm
Was researching this topic recently, as I scored some vintage
Watenabes for my AE86, and found the stock studs were not long
enough to get the proper number of turns on the wheel nuts. This
is what I found...
The only useful measurement is the length (measured from under
the head) as hub thickness and brake discs can affect the amount
of stud you can see.
All of these studs have the 14.17-14.20 knurl and will happily pull
into AE86 hubs without raising a sweat. A lot of the Toyota studs
are used on more than one vehicle, and may have "replaced by"
part numbers different from the original.
Cheers... jondee86
Watch this space >>> <<<
jondee86
Postby Snoozin » Sun Aug 04, 2013 12:58 pm
Thanks mate, I was JUST searching this very information to get something longer for the front of my KP.
Still got the 14" Harts I sold you some time ago?
Snoozin
Postby Bling » Sun Aug 04, 2013 2:51 pm
Good info. Are the Landcruiser studs the longest available from Toyota, or did you just try a few examples till you found the length needed?
Postby jondee86 » Sun Aug 04, 2013 5:40 pm
Snoozin wrote:Thanks mate, I was JUST searching this very information to get something longer for the front of my KP.
Got these off tardme a while back...
Sellers description was a bit astray, but they turned out to be a
pair of 14 x 6 (+16) and a pair of 14 x 6.5 (+9) which is good
enough for me 8) For some reason Wats just look like they
belong on an 86... and I'd been looking for a set for a while.
Loved the Harts but in the end gold wheels just didn't look right
to me on this car, so I sent them to a good home in Nelson. The
"Lexus" studs I knocked out of a Toyota MPV at Pick-Apart, and
they seem to be used on a whole bunch of different Toyotas. So
if they are long enough for you, they would be the easiest to get.
Cheers... jondee86
jondee86
Postby jondee86 » Sun Aug 04, 2013 6:24 pm
BZG|Bling wrote:Good info. Are the Landcruiser studs the longest available from Toyota,
They are the longest 12 x 1.5 I found with the correct 14.20 knurl.
NICE Products in Aussie do a longer stud with a 14.30 knurl, and
it is claimed that these will press into the Toyota hub. I knocked
some 41mm studs out of a L300 or Hiace type van at Pick-Apart,
and they had a 14.30 knurl. BUT, when I tried them against the
AE86 hub I found that the base diameter of the shank with the
knurl was bigger than the hole in the hub (14.0 vs 13.73).
So you could look at the NICE S381 at 48mm long. Just check the
hole size in your hub and the shank size at the knurl. BNT have
them as stud c/w nut for about $12 a pop !!! The Cruiser ones were
over $8 each from Mark. ARP also do long studs for even more $.
Cheers... jondee86
jondee86
Postby mint_86 » Sun Aug 04, 2013 9:39 pm
I just fitted some ARP IS300 extended studs to my AE86. they are mega long:
http://www.summitracing.com/parts/arp-100-7715
mint_86
Postby jondee86 » Sun Aug 04, 2013 9:54 pm
mint_86 wrote:I just fitted some ARP IS300 extended studs to my AE86. they are mega long:
66 long with 14.17 knurl... should fit like a glove :) Did they pull
in easy if you used the wheel nut and a bit of grease method ?
Cheers... jondee86
jondee86
Postby mint_86 » Mon Aug 05, 2013 8:46 am
66 long with 14.17 knurl... should fit like a glove Did they pull
Cheers... jondee86
Yea man, it was no trouble pulling them in. Had to pull the axles slightly on the rear though to get them in.
mint_86
