quick question guys..
Postby mega4a » Sat Aug 10, 2013 5:07 pm
if i was to remove the heater core on my car would it be better to block or loop the pipes on the motor ? and what do you guys think on removing the heater core better cooling or worse cooling i know the header core acts as a radiator but was jut wondering what everyone thought.
DAILY DRIVEN.
230HP ATFW AE100 WAGON 4AFTE MEGASQUIRT.
1999 Toyota Corolla BZ Touring wagon 4age 20v bt.
1996 Toyota Truneo 5AFE
mega4a
Postby Lloyd » Sat Aug 10, 2013 5:11 pm
It generally makes no difference to cooling. And loop it.
Postby mega4a » Sat Aug 10, 2013 5:13 pm
why loop it ?
DAILY DRIVEN.
mega4a
Postby Grrrrrrr! » Sat Aug 10, 2013 5:26 pm
why remove the heater core? is it leaking, or are you stripping it out for racing?
Grrrrrrr!
Postby matt dunn » Sat Aug 10, 2013 5:39 pm
Lloyd wrote:It generally makes no difference to cooling. And loop it.
It generally makes no difference,
and don't loop, it block it.
Looping it lets water circulate bypassing the radiator with losing heat,
so the cooling system looses efficiency.
Postby mega4a » Sat Aug 10, 2013 6:25 pm
Grrrrrrr! wrote:why remove the heater core? is it leaking, or are you stripping it out for racing?
just because i don't plan on driving it daily anymore so id only be driving it on weekends for some fun and taking down the drag strip and taking it to track days so i was just planning on stripping out shit that isn't really needed and i want to tidy up the engine bay as well and those heater hoses are ugly !!
DAILY DRIVEN.
mega4a
Postby mega4a » Sat Aug 10, 2013 6:28 pm
yeah i plan on getting ronnie to weld it up so there both blocked ill take a photo and up load it see what you guys think if i should block or not
DAILY DRIVEN.
mega4a
Postby mega4a » Sat Aug 10, 2013 6:44 pm
here we go the two big holes are the heater hose and the two lil ones out the side go to throttle body
DAILY DRIVEN.
mega4a
Postby suprra_girl » Sat Aug 10, 2013 7:50 pm
You will need to keep the hoses going to the throttle body as they warm it up, as for the heater hoses you can generally just loop them, I'm not sure what engine you have so can't post specifics.
edit: oh sig lol, still doesn't help me, I don't know how those engines route :p
suprra_girl
Postby jondee86 » Sat Aug 10, 2013 8:07 pm
I've got a feeling that you need a heater for a WOF. Something to
do with de-misting the screen if I remember rightly.
Cheers... jondee86
Watch this space >>> <<<
jondee86
Postby Lloyd » Sat Aug 10, 2013 8:26 pm
No need for a warrant.
Postby mega4a » Sat Aug 10, 2013 8:41 pm
suprra_girl wrote:You will need to keep the hoses going to the throttle body as they warm it up, as for the heater hoses you can generally just loop them, I'm not sure what engine you have so can't post specifics.
hey the hoses to the throttle are already looped i don't run them as i want coldest intake temp possible with turbo.
its all good thanks for posting anyway
DAILY DRIVEN.
mega4a
Postby mega4a » Sat Aug 10, 2013 8:45 pm
jondee86 wrote:I've got a feeling that you need a heater for a WOF. Something to
Cheers... jondee86
wofs are not an issue i can get them easily enough. but i don't think that would fail a wof would it? i don't think it would be classed as unsafe? and i was thinking of keeping the blower so it would just blow cold air on to the window to de fog it.
DAILY DRIVEN.
mega4a
Postby wde_bdy » Sat Aug 10, 2013 8:50 pm
Don't need the heater core in, need the fan though or some other demisting option.
Callum
wde_bdy
Postby Lloyd » Sat Aug 10, 2013 9:48 pm
Since when? (genuine question, never seen it in the VIRM)
You shouldn't need any form of demisting for a warrant. It comes down to a vehicle operation charge if you're driving with the car fogged up, no a vehicle safety inspection problem. This is the impression I was under.
Postby matt dunn » Sat Aug 10, 2013 9:55 pm
However,
from the motorsport nz manual
5.11 Windows: shall meet the following requirements;
(3) The front windscreen shall have an effective method of demisting, either by ducting of air, hot wire elements, or have an anti-fogging coating applied...
says air, but not hot air,
or anti-fogging compound but have found that is only good to a point.
Postby wde_bdy » Sat Aug 10, 2013 10:29 pm
Lloyd wrote:Since when? (genuine question, never seen it in the VIRM)
You are only pernmitted to make a modification without cert if the VIRM allows it. If not specifically allowed then by default a cert is required.
Callum
wde_bdy
Postby Lloyd » Sat Aug 10, 2013 10:45 pm
You're sounding a lot like a VTNZ employee right now
Postby jondee86 » Sun Aug 11, 2013 1:06 am
suprra_girl wrote:... as for the heater hoses you can generally just loop them.
The heater usually takes hot water from the head, runs it thru the
heater core, and returns it to the cooling system. Logic says that
shutting the heater valve off will not prevent the water flowing out
the back of the head. So it would seem that the cooling system
does not care if there is a heater core in the car or not.
Putting a loop of hose where the heater used to be should work,
providing that the water circuit stays essentially the same as when
the heater valve is closed :)
Cheers... jondee86
jondee86
Postby allencr » Sun Aug 11, 2013 8:14 pm
Looping is just adding another bypass.
If you want coolant bypassing the radiator AND don't have a marginal cooling system, do it.
allencr
