Banjo fitting
Banjo fitting
Postby Scottie » Tue Oct 22, 2013 6:30 pm
Anyone know where to get a 12x1.25 banjo bolt with a pipe thread or barb fitting out the top of it locally.
Like this
Scottie
Postby Crucible » Tue Oct 22, 2013 8:16 pm
Any hose doctor like enzed or hydralink should be able to help.
Crucible
Real Life Mechanic
Postby Scottie » Tue Oct 22, 2013 8:29 pm
Thanks, but hydraulic fittings are not 12x1.25. I think I may end up having to make something.
Scottie
Postby Crucible » Wed Oct 23, 2013 7:04 am
Really..I would of thought they could supply or at least source? Yeah wouldnt be hard to make something, braze a barb on to suit.
Crucible
Real Life Mechanic
Postby edwagon » Wed Oct 23, 2013 8:34 am
I'd try a Diesel and Turbo place - they'll have something automotive specific that'd do it
edwagon
Postby Soiled » Wed Oct 23, 2013 4:49 pm
Soiled
Postby evil_si » Wed Oct 23, 2013 8:12 pm
Scottie wrote:Thanks, but hydraulic fittings are not 12x1.25. I think I may end up having to make something.
You'd be surprised, hydraulink have a huge range in their catalogues, Ive bought plenty of metric banjos from them,
Last couple ive needed ive brazed a boss to the banjo, have also had a couple where the head was thick enough to be able to drill and tap to 1/8bsp
evil_si
Postby Scottie » Thu Oct 24, 2013 9:08 pm
Hydraulink only had normal banjo bolts in 12x1.5 aswell. Should be all sorted now, bought some barbs and should have a bolt somewhere at home.
Scottie
Postby allencr » Fri Oct 25, 2013 6:16 am
Brazing can be good for thousands of PSI, soldering can easily handle a fuel pump unless it's a poor mechanical joint and a poor solder joint.
allencr
Postby Crucible » Fri Oct 25, 2013 10:14 pm
allencr wrote:Brazing can be good for thousands of PSI, soldering can easily handle a fuel pump unless it's a poor mechanical joint and a poor solder joint.
Your not wrong.
I remember back in my pre-trade tech days in welding class, one of the tests was to braze 10mm mild steel plate, veed butt joint which was then put in a press. If you got it right the plate would bend 90 degrees with no affect to the joint.
Pretty impressive stuff.
Crucible
Real Life Mechanic
Postby TWSTD » Sat Nov 09, 2013 9:44 pm
Yes from us - your official Toyspeed sponsors!
http://www.drivenperformance.co.nz/scri ... oduct=1715
That what you after?
Click here!
TWSTD
