4age gearbox differences
Postby Kiwi6539 » Wed Nov 06, 2013 8:11 pm
Hi all.
Can anyone tell me how to tell the difference visually between a E56 AND C160 LSD gearboxes.
Or if there's any numbers or ways to tell.
I have a 20 valve silvertop and gearbox at work shop. The gearbox from what I know is lsd.
I know the silvertop never came with lsd as far as I know.
So wanting to see if there's a chance it's a C160 6 speed. Or its the 5 speed E56
Also I'm looking for camber plates for a ae82 1985 if anyone has any to sell.
NZ New AE82 Gt race car
Kiwi6539
Postby rollaholic » Thu Nov 07, 2013 6:51 am
im pretty certain that silvertops and LSDs did come together from time to time, and im also pretty certain the 6 speed only came with blacktops.
then again if its not the original gearbox then im out of ideas, never had dick to do with C160s so wouldnt know one from a bar of soap :)
from the way everyone talks on here, you are better off without a 6 speed anyway.
if you are wanting to know how many gears it has, rather than if its LSD or not, surely you could just check that with the shifter linkages?
Postby RobertC » Thu Nov 07, 2013 11:48 am
Post a picture looking through the axle hole this will allow identification of lsd or not. Then pictures of the tops of the boxes and then can say if 5 or 6 speed.
MRAE111 wrote:ok thanks guys but wen u dont have trmpets i think the air flow quickeer into the throttle bodies
RobertC
Postby jacobrjett » Thu Nov 07, 2013 2:02 pm
you should be able to count the gears by moving the linkages on the box? although reverse is quite stiff on c160s (or was on mine)
jacobrjett
Postby RobertC » Thu Nov 07, 2013 2:29 pm
the bolt holes on for the gearbox mount on a c56 make a triangle
on c160 the bolts are in a line
RobertC
Postby Flannelman » Sat Nov 09, 2013 7:49 am
E56 is a much bigger and heavier unit, with a steel removable panel opposite the bell housing. The output shafts are much bigger as well.
The Flannel, formally known as Affroman
Flannelman
formerly known as Affroman
Postby rollaholic » Sat Nov 09, 2013 4:01 pm
im pretty sure he meant C56, since AFAIK silvertops never came with an E box
