AE86 Diff assembly questions
Postby andyling » Thu Feb 06, 2014 11:13 pm
Hi guys
Trying to assemble the diff myself,
I am following the instruction
http://www.aeu86.org/index/axle-amp-dif ... post=78515
I don't get, why do you preload the pinion bearing without crush tube, and assemble the carriers, torque it up.Then remove the pinion bearing again and put crush tube in and bearing on again?
Why? and How do you remove the bearing without dissemble the carriers?
Any easier methods?
Thanks in advance.
andyling
Re: AE86 Diff assembly questions
Postby Pelo » Fri Feb 07, 2014 10:36 am
moved to tech section as requested :)
Pelo
Postby Bling » Fri Feb 07, 2014 12:14 pm
My suggestion would be to let a professional put it together for you. That is the easier / better method. It needs to be done just right or else you may damage the parts.
Postby jondee86 » Sat Feb 08, 2014 11:01 am
andyling wrote:I don't get, why do you preload the pinion bearing without crush tube, and a
The first time the pinion is installed and the bearings pre-loaded, is to check
that you have the correct shim washer to give you a proper contact patch when
the crownwheel is installed into the carrier. The factory consider crush tubes
to be a one time use item, so if you had to change the shim, you would need
to use another new crush tube.
If you don't need to change the shim, then you don't need to take the pinion
out, just pull the front bearing, put the tube in and torque it up.
Cheers... jondee86
Watch this space >>> <<<
jondee86
Postby andyling » Sat Feb 08, 2014 10:12 pm
Cheers... jondee86
Thanks man, that helps heaps.
How do you pull the front bearing out without taking the pinion out?
andyling
Postby jondee86 » Sat Feb 08, 2014 10:47 pm
You need a puller like this one...
Works like this....
Cheers... jondee86
jondee86
