d1 mule wrote:would also be questioning why it only made 240 whp
Dell'Orto wrote:Man is that super laggy or did they not rev it right out? I would hazard a guess given your latest questions that your cam timing is out
iamawesome wrote:Seems very odd, did Geoff tune it at all? And just out of curiousity, how did you get put on to him?
Dell'Orto wrote:Yeah look how much later it makes full boost now. Either timing is out or its lost lots of compression
Flannelman wrote:Whats been changed since the dyno runs?
Flannelman wrote:Whats the new spring rates?
New valve springs mean cam removal. I would be checking cam timing closely, (the intake cam could be retarded one tooth) followed by correctly adjusted throttle - is it getting 100%? No blockages in intake track? Are the air cleaners clean?
Flannelman wrote:Just a tip, use a long thin screwdriver down the spark plug hole to see where TDC is if the timing marks are suspect.
JZCrazy wrote:What gear was it Dynoed in?
