.Cometic wrote:What head bolt/stud torque do you recommend when using an MLS gasket?
When using MLS head gaskets always refer to the manufacturer of the fastener to determine accurate torque values. Appropriate torque is critical when installing new gaskets of any kind.
Grrrrrrr! wrote:And yet the dodge tsb for changing from composite to mls headgaskets
in 2.0l sohc and 2.4l engines says to use the same torque values as with
composite gaskets.
If mls headgaskets required different torque values they would supply the torque values
with the gaskets.. but they dont. They supply different torque values with aftermarket
head bolts/studs because that is what determines the correct clamping force.
As for tty bolt vs std bolt.. for the 16v 4age they are the SAME bolt, toyota revised
the torquing procedure as the engines went up in power output to acheive higher and
more consistent clampling pressure.
Does this mean they used the same specific torque, or the same torque-angle method ?
Bazda wrote:Doesnt matter what gasket you use.
Cylinder Head Installation For 1999-2006 Chrysler/Jeep 4.7L VIN J & N Engines
The cylinder head bolts on 1999-2006 Chrysler/Jeep 4.7L VIN J & N engines. are tightened
using a Torque-To-Angle procedure commonly referred to as TTA. Even though the cylinder
head bolts are tightened using torque and an angle procedure, the bolts are not a
Torque-To-Yield TTY, which are a single use design.
Therefore,TTA bolt re-use is possible if each bolt is “qualified” (examined for neckdown) first.
If the threads are necked down, the bolts should be replaced. One method of checking for
neck-down is to use a like-size nut and check to make sure you can easily thread it along the
entire threaded area of the fastener. Once reuse or replacement is determined, follow the
steps listed below to install the cylinder heads for these engines.
1) Clean the cylinder head and cylinder block mating surfaces.
2) Position the new cylinder head gasket on the locating dowels.
When installing cylinder head, use care not to damage the tensioner arm or the guide arm.
3) Position the cylinder head onto the cylinder block.
Make sure the cylinder head seats fully over the locating dowels. Note: The four smaller
cylinder head mounting bolts requiresealant to be added to them before installing. Failure
todo so may cause leaks.
4) Lubricate the cylinder head bolt threads with clean engine oil and install the ten M11
bolts finger tight.
5) Coat the four M8 cylinder head bolts with Mopar Lock & Seal Adhesive (or aftermarket
equivalent), and then install the bolts finger tight.
6) Tighten the bolts in sequence shown above in Figure 4, using the following steps and
torque values:
1) Tighten bolts 1-10, 15 ft. lbs. (20 Nm).
2) Tighten bolts 1-10, 35 ft. lbs. (47 Nm). Tighten bolts 11-14, 18 ft. lbs. (25 Nm).
3) Tighten bolts 1-10, 90°. Tighten bolts 11-14, 22 ft. lbs. 30 Nm).
The biggest reason that most [myself included until recently] consider the
new style bolts to be TTYs is the appearance of the bolt itself: it has the
reduced diameter section between the head and the threads. Combine the
appearance with the angle tightening and the reasonable conclusion to be
drawn is that they are indeed TTYs.
BUT, there is one very important thing that needs to happen when tightening
down a TTY bolt that does NOT happen when tightening down the new style
bolts on a Volvo redblock: the YIELD.
In all the motors on which I have tightened down the new style bolts,
following the factory procedure [15 lbs-ft, 45 lbs-ft, angle tighten 90
degrees], I have never felt the bolts yield. And when a bolt yields, you CAN
feel it. It feels like you have started to pull the threads. I have
overtightened bolts on other things; I KNOW the feeling of the yield.
The new style bolts are NOT TTYs; they are TATs.
The use of a lubricant under the bolt head and threads, as mentioned, will alter
the torque rating substantially, and should be used if recommended by the bolt
or engine manufacturer. This fact is often overlooked and a wet torque specification
is used with a dry bolt, resulting in a lack of clamping force; if a dry specification
is used wet, the exact opposite will occur. The bolt will now be over-torqued,
with possible internal damage from entering its plastic range.
jondee86 wrote:There is no problem is following the manufacturers instructions when replacing
an OEM head gasket with the same type of OEM gasket, and using OEM bolts.
The problems arise when people start changing stuff around. There is a huge
amount of confusion about whether the OEM head bolts on certain engines are
TTY or not ?
And lastly but by no means of least importance, is the question of should TTY bolts be installed dry or lubricated....
jondee86 wrote:What is not known is whether the bolt goes beyond the elastic limit and into
the plastic region.
Of if you like, how much torque can the bolt handle before
it gets into the plastic region?
Users browsing this forum: Google [Bot] and 17 guests
