Grease driver side wheel arch - CV boot seems intact
Postby blobbi » Fri Sep 16, 2016 5:48 pm
I changed my brake pads a couple of weeks back and then yesterday saw some grease on inside of the driver side wheel arch. I thought it must be the outer CV joint. I changed the boot today but in all honesty although it has deteriorated I could not find a hole in it that would cause the loss of grease and there was heaps of grease in the boot. Am I missing somewhere else that this grease might be coming from or could it have crept out of the ends or similar?
Thanks
Rob
blobbi
Re: Grease driver side wheel arch - CV boot seems intact
Postby thegreatestben » Sat Sep 17, 2016 11:49 am
Earlier failure that hadn't been cleaned up?
thegreatestben
Postby blobbi » Sat Sep 17, 2016 11:51 am
Thats what I thought but it wasn't there when I did the brakes the other day and the boot I took off looked like it was on the car for a while. Maybe one of the clamps was loose or it chucked out some grease under pressure.
blobbi
Users browsing this forum: Google [Bot] and 24 guests
