ROBODISCO_20v wrote:If you want the best value for $ option go into your local repco or appco store, they have the air flow metre adaptor plates for $20, they also have Simota pod filters for $50. They can also supply a heat sheald for around $30
So for half the price of a K&N panel filter you've got yourself a nice setup.
If you have any problems i will get you the part numbers, failing that if you are in the auckland area come over to Appco in Wairau Rd and ask for Carl and he will suss you out a deal
neo wrote:with the factory airbox, a 3" duct will fit straight into the hole in the box where the twisty factory intake goes.. a hold in the inner guard, and intake from narm =)
pluck wrote:neo wrote:with the factory airbox, a 3" duct will fit straight into the hole in the box where the twisty factory intake goes.. a hold in the inner guard, and intake from narm =)
How much would that cost?
How much louder and faster would my car run?
ROBODISCO_20v wrote:You geeks with your standard 101's
You dont need an air box with your pod, a pod increases air flow 10 times better than your factor air box. My ae111 blacktop 20v has an HKs pod without an air box/heat sheild around it and it is so much better than any factor air box with a k&n in it that i've had in my previous cars.![]()
A K&N panel is going to set you back at least $140-$180 you could put a repco (simota) pod on and build a heat sheild for half that. You can buy small heat sheilds from repco for about $30 also.
AE101 Levins suck !!! get a black top up ya !!!!!!!!
Users browsing this forum: Bing [Bot], Google [Bot] and 7 guests
