Pod Filter in a Ae101 20v
Postby pluck » Mon Sep 15, 2003 1:58 pm
How easy is this to do?
Could I do it by myself? what else do I need other that the pod filter?
E.g. can i just remove the stand one and plug the pod filter onto the end of the pipe. I heard I might need some plastic tubing for cold air intake or something?
pluck
Postby AceSniper » Mon Sep 15, 2003 3:34 pm
If your going to put the pod were your air box is with no cold air box dont bother, to fit a pod you need an adapter to bolt onto the afm, i found the best way was get a good panel filter run some pipe from the front of the bumper so its ramed abit... up through the hole in the guard were the resignater box is and then into the factory box, make sure the pipe is cut flush with the box then silicon around it so no air can get in...
but every one has there own tricks... so yea... i had a pod but once the engine bay warmed up went to crap, stalling and shit
AceSniper
Postby pluck » Mon Sep 15, 2003 4:39 pm
Where would you usually put a pod filter, I assumed you would just put it where the air filter is at the moment, sort of as a replacement?
pluck
Postby aaron » Mon Sep 15, 2003 5:34 pm
the adaptors for the pod filter dont cost $&#$% all but if your not gonna do a cold air box then a replacement panel would be sweet not sure on cost but would be all you need. iduction pipes would help too
Owned cars:
4age powered 1973 ke25 corolla
4k powered 1974 ke25
AE101 20v trueno
AE92 Levin
http://toyspeed.blakjak.net/profiles/profile.php?id=68
aaron
Postby pluck » Mon Sep 15, 2003 6:11 pm
what is a replacement panel?
pluck
Postby aaron » Mon Sep 15, 2003 6:27 pm
just a filter the same as the one u already have in the air box(panel filter) except beter flowing k&n make one specially and so do several other names you wont have to change any thing just buy the filter unclip the top of your air box and swap it with the old one.
Owned cars:
AE101 20v trueno
AE92 Levin
aaron
Postby Lloyd » Mon Sep 15, 2003 7:47 pm
I know this is for an AE92, but it may be similar. Gives you the ideas anyway: http://www.4age.net/tech/coldair.htm
Postby pluck » Tue Sep 16, 2003 1:02 am
Think i'll just go with the replacement panel. Where can I get a good one from? Repco??
pluck
hi
Postby icy » Tue Sep 16, 2003 2:00 am
ya i think you can just get them from repco .
you will never learn how to swear properly untill you learn how to drive
icy
Postby neo » Wed Sep 17, 2003 2:08 am
with the factory airbox, a 3" duct will fit straight into the hole in the box where the twisty factory intake goes.. a hold in the inner guard, and intake from narm =)
neo
Postby ROBODISCO_20v » Thu Sep 18, 2003 7:50 pm
If you want the best value for $ option go into your local repco or appco store, they have the air flow metre adaptor plates for $20, they also have Simota pod filters for $50. They can also supply a heat sheald for around $30
So for half the price of a K&N panel filter you've got yourself a nice setup.
If you have any problems i will get you the part numbers, failing that if you are in the auckland area come over to Appco in Wairau Rd and ask for Carl and he will suss you out a deal
ROBODISCO_20v
Postby AceSniper » Thu Sep 18, 2003 10:12 pm
ROBODISCO_20v wrote:If you want the best value for $ option go into your local repco or appco store, they have the air flow metre adaptor plates for $20, they also have Simota pod filters for $50. They can also supply a heat sheald for around $30
thats a pod... pod = need air box or its crap
thats why the panel was sugested
AceSniper
Postby pluck » Fri Sep 19, 2003 3:41 pm
neo wrote:with the factory airbox, a 3" duct will fit straight into the hole in the box where the twisty factory intake goes.. a hold in the inner guard, and intake from narm =)
How much would that cost?
How much louder and faster would my car run?
pluck
Postby AceSniper » Fri Sep 19, 2003 4:07 pm
$10 duct (max)
cost of the filter
iv got this setup.. also since the hole into the air box isnt round sealing off the holes around the tube/box is a must, I used silicon, and if you pull it thought the hole in the inner guard around to the front you can get some RAM happening.
No matter what you do with a 20v you dont really get induction sound
AceSniper
Postby pluck » Fri Sep 19, 2003 6:00 pm
Where did you get your panel filter from?
I know you from about 3 years ago, I thought I recognised the name neo. I used to live in Jville and knew one of your (im guessing) ex girlfriends.
pluck
Postby ROBODISCO_20v » Sun Sep 21, 2003 4:59 pm
You geeks with your standard 101's
You dont need an air box with your pod, a pod increases air flow 10 times better than your factor air box. My ae111 blacktop 20v has an HKs pod without an air box/heat sheild around it and it is so much better than any factor air box with a k&n in it that i've had in my previous cars. :roll:
A K&N panel is going to set you back at least $140-$180 you could put a repco (simota) pod on and build a heat sheild for half that. You can buy small heat sheilds from repco for about $30 also.
AE101 Levins suck !!! get a black top up ya !!!!!!!!
ROBODISCO_20v
Postby AceSniper » Sun Sep 21, 2003 7:19 pm
ROBODISCO_20v wrote:You geeks with your standard 101's
you wait will your stuck in traffic during the summer eh ull notice for sure when the pod starts sucking hot air, and i had a filter custom made for $50 that flows nicely
AceSniper
Postby iplen » Sun Sep 21, 2003 11:10 pm
yeah, well get stuck in and make your blacktop produce some real horsepower, then see what happens to your rods to start with, then compare modified figures with a silver top, and don't be too dissapointed. But 16v will still do better than both.
AE101 rally car- ??.?? @???km/h- quicker that Mirage Cyborg, Honda Civic, HSV Clubsport.
iplen
Postby Loudtoy » Tue Sep 23, 2003 12:14 am
Tis true whilst you are moving but stop moving for a short amount of time and instant heat soak! I'm not going to say anything bout the geeks with standard 101's comment cos funnily enough i think you'd have a reasonably hard time keeping up with my 101! In fact i don't think you could keep up at all 8O
TS Member sine 2001
Prado To tow stuff with
Rodeo to do work stuff in
Loudtoy
Postby ROBODISCO_20v » Thu Sep 25, 2003 12:10 am
I've owned 2 silvertops and i can honestly say they are crap compared to blacktops. My engine has been lightly modified by the previous owner with the likes of new cams, air filter & exhaust and i dont have any problems with my lighter internals . In fact they make the engine rev better/freely in comparison to the dirty old silvertop. The guy i bought my car of had an ae101 as a rally car, he'd spent $20K on the engine and said his street ae111 was better.
And as for Mr G Tech man take your car to a drag proper drag strip and show me the real time, I guess we'll have to arrange a race then so i can beat you :lol:
ROBODISCO_20v
