Hey guys. I bought an awesome manifold with TD05HR turbo for a good deal, that came from a race spec Corolla, so FWD. Have just test fitted, and while it bolts up fine, the inlet to the turbo opens to all the gearbox linkages n shit, practically touching them. Of course, that shit is on the other side of the gearbox on Corollas. I have no doubt itd run fine, but I would like some sort of air filter or inlet piping on it, which is just not going to happen as is. Rerouting the linkages and clutch lines/slave cylinder is not an option.
I have enough room to maybe fit a mesh screen with some sort of foam covering. What should I do? If I have to, I will source another manifold and/or turbo - but Id like to avoid this if at all possible.
