Hi team,
I have a 2002 corolla (e120?) With the 1.5L engine.
It has developed a fairly bad miss under acceleration between 1000 & 3000rpm. It idles fine, and once past 3000 it is fine.
It improves once the car is up to temp, but It's particularly bad for the first 5 minutes after a warm start.
Google and my guess agree there are a few possible causes.
- afm
- o2 sensor
- fuel supply (pump/pressure regulator etc?)
-plugs etc
Rather than start replacing these 1 by 1 and inevitably find out the problem is the last thing I replace, does anyone have any suggestions on how to isolate the problem?
Tia
