Bad miss under acceleration 2002 corolla
Post Reply
RAZA
Contact:
Post by RAZA »
Hi team,
I have a 2002 corolla (e120?) With the 1.5L engine.
It has developed a fairly bad miss under acceleration between 1000 & 3000rpm. It idles fine, and once past 3000 it is fine.
It improves once the car is up to temp, but It's particularly bad for the first 5 minutes after a warm start.
Google and my guess agree there are a few possible causes.
- afm
- o2 sensor
- fuel supply (pump/pressure regulator etc?)
-plugs etc
Rather than start replacing these 1 by 1 and inevitably find out the problem is the last thing I replace, does anyone have any suggestions on how to isolate the problem?
Tia
Currently driving:
BMW 135i M
GDII
Re: Bad miss under acceleration 2002 corolla
Post by GDII »
Coils can give up on these engines. I assume it's the 1NZFE based on the 1.5litre capacity.
Spark plugs are good to just replace anyway. You can pick between the 5 types of DENSO or NGK
http://www.globaldenso.com/cgi-bin/glob ... ion=search
https://www.ngk.com/product.aspx?zpid=9326
1990 SW20 MR2
Previous 1990 EE90 Corolla
Post by xsspeed »
Sounds symptomatic of failing coil(s)
Are these coil on plug?
RAZA
Contact:
Post by RAZA »
Thanks for the replies. It is the 1nzfe.
Any suggestions on how to check the coil packs? unplugging them one at a time while at idle doesn't tell me anything as it runs fine at idle. Am trying to avoid buying new ones then finding the fault lies elsewhere.
Currently driving:
BMW 135i M
Contact:
Post by matt dunn »
Going from your explanation it really sounds like a failing coil.
They are hard to tell which one though.
Sometimes it is just as easy to get one, fit it to cyl 1 and try it.
If not fixed try cyl 2, then 3 then 4 etc.
OR see if there is a fault code in the system,
possibly not though from a coil fault.
RAZA
Contact:
Post by RAZA »
Ok cheers will get hold of a coil and give that a go.
Currently driving:
BMW 135i M
Flannelman
formerly known as Affroman
Post by Flannelman »
Plug gap.
Got a BA Falcon that had the same issue. Stutter when cold, got better when hot. Guy replaced coils and was still there.
Gap was 1.7mm!
The Flannel, formally known as Affroman
Contact:
Post by matt dunn »
Flannelman wrote:Plug gap.
Gap was 1.7mm!
Thats a common issue on the Falcons, as the factory gap on them in either 1.3 or 1.5mm from memory,
and the coils have a weak arse spark anyway.
We always put in plugs with a more standard gap than spec on them.
Post Reply
