What are these throttle bodies (pic)?
All the Frequently Asked Questions which are of a technical bent. Look here before posting a tech query.
Postby anthonym » Tue Jul 19, 2005 9:01 am
Can anyone identify the throttle bodies (part 3 in the exploded drawing) in this (TRD Altezza) intake? Apparently they're a standard Toyota part. And if you know what they are, what is the i/d? Thanks :)
anthonym
Postby RomanV » Tue Jul 19, 2005 12:01 pm
Well how many toyota 4cyl engines came with quad throttles?
Only the silvertop and blacktop 4AGEs as far as I know.
I hear about 4AGE quad throttles being used all the time for conversions, it wouldnt surprise me if TRD used them too.
I mean you can buy a kit to fit them to 1uz's.
My guess would be that they are blacktop 4age throttles, since they have larger diameter than silvertop IIRC.
However I have no idea of the actual dimensions you require.
Postby fivebob » Tue Jul 19, 2005 12:51 pm
IIRC they are 43mm for the silvertop & 45mm for the Blacktop, just the right size for my 3l V8 :wink:
Area of these is equivalent to a bit less than 86mm & 90mm single T/Bs, but more than enough to extract prodigious amounts of HP from any engine.
Postby TRD Man » Tue Jul 19, 2005 1:43 pm
Anthony,
Both the picture & the diagram are the TRD throttle body set for Altezza 3SGE.We haven't confirmed officially but we have taken the time to measure & compare the TRD throttle body with a set of blacktop ones we have here.
Not surprisingly, they appear to be a perfect match. Which I guess is why the TRD set can be purchased complete or as separate items.
Bruce
TRD Man
Postby BBBrad » Tue Jul 19, 2005 9:54 pm
[quote="fivebob"]IIRC they are 43mm for the silvertop & 45mm for the Blacktop, just the right size for my 3l V8 :wink:
Say what??? Do explain please.
My new car...99 mr-s
BBBrad
Postby Mr Revhead » Tue Jul 19, 2005 10:08 pm
the TRD ones are listed as Toyota Genuine Parts, however you can only buy them as a complete setup from either Toyota or TRD. with the TRD ones you can however buy the other parts seperatly
Postby fivebob » Tue Jul 19, 2005 10:09 pm
BBBrad wrote:
fivebob wrote:IIRC they are 43mm for the silvertop & 45mm for the Blacktop, just the right size for my 3l V8 :wink:
Take this, which has the Toyota T/Bs;
add a Motec and a couple of CT20Bs, then make some sort of sealed plenum similar to this;
Very sacreligious I know, but the cheapest way I can think of to get a 600HP Ferrari :twisted:
Postby Mr Revhead » Tue Jul 19, 2005 10:11 pm
nice. very nice.
how do i arrange a ride? :D
Postby fivebob » Tue Jul 19, 2005 10:12 pm
Mr Revhead wrote:the TRD ones are listed as Toyota Genuine Parts, however you can only buy them as a complete setup from either Toyota or TRD. with the TRD ones you can however buy the other parts seperatly
:? Does this mean you can't buy the Throttle Bodies seperately :cry: hmm might be cheaper to buy a couple of second hand engines then :roll:
Postby anthonym » Tue Jul 19, 2005 10:19 pm
Thanks for all the excellent replies everyone. I had assumed 8O that blacktop throttlebodies were <45mm, as that seems excessive for a 1.6. Interestingly the stock Altezza intake is slightly smaller than 45mm at the narrowest point, but the actual ports are substantially larger than this (oval 53 x 43mm) and are not drastically tapered as they run down to the valves. Dosen't really make much sense to me.
anthonym
Postby Mr Revhead » Tue Jul 19, 2005 10:24 pm
let me clarify....
edit: see post below, i goofed :oops:
from TRD you have to buy all the parts listed in the bracket marked 1
you cannot buy 3 seperatly.
second hand you can get the ae101 t/bs for $100-150
the blacktop ones are often $200 or more....
if your not in a hurry keep an eye out, every now and then deals pop up, like complete blacktop heads with t/bs for under $300
heres the toyota ones
Postby anthonym » Tue Jul 19, 2005 10:28 pm
Mr Revhead wrote:let me clarify....
from Toyota you have to buy the whole assembly.
And by whole assembly do you mean just the 4 throttle bodies without all the other gumf (like item 3 in the TRD pic I posted)?
anthonym
Postby vvega » Tue Jul 19, 2005 10:32 pm
fivebob wrote:add a Motec and a couple of CT20Bs, then make some sort of sealed plenum similar to this;
hopfully my little aw11 will look very much like that
i dont think the e 153 would handel the 600 hp tp well
whats the box uesd on that engine ??
v
vvega
Postby Mr Revhead » Tue Jul 19, 2005 10:37 pm
sorry my bad :oops:
from toyota you CAN buy them seperatly, as in the set of four basic t/bs
p/n 22211-16760
Postby Adamal » Tue Jul 19, 2005 10:39 pm
Now, what is the car thats in? Is it just me, or is that an AW????
Postby fivebob » Tue Jul 19, 2005 10:40 pm
Ahh I see now, looks like the Toyota ones don't have the trumpets but have a lot of other stuff that I wouldn't need.
Not in a hurry, still got to get the car back on the road (just ordered $20k of panels for it 8O ). I keep looking for them but I never seem to be in the right place when the parts come up for sale, usually when I'm still in Aus. :evil: Thought it might be easier to get new parts, but alas it appears not, pity as I could probably sell a few EFI conversion kits to defray my expenses.
Postby fivebob » Tue Jul 19, 2005 10:42 pm
Adamal wrote:Now, what is the car thats in? Is it just me, or is that an AW????
It's just you, unless AW11's were made in Italy and had the Cavallino Rampante emblem on them :twisted:
Postby Adamal » Tue Jul 19, 2005 10:45 pm
Huh? What? Where??? :oops:
Postby Mr Revhead » Tue Jul 19, 2005 10:45 pm
fivebob, can i tell him what it is? :D
go 2nd hand, they are easy to find. if ae101 ones are ok, i can do as many as you want for about $130-150 each. blacktop ones are as i said, a bit more.
keep looking, they're out there
Postby vvega » Tue Jul 19, 2005 10:46 pm
and the layout of the gearbox ???
v
vvega
Return to Technical FAQs - General
