Optical to XLR DAC
Optical to XLR DAC
Postby sergei » Thu Jul 21, 2005 11:57 pm
Not realy car audio related, but I need a "box" that will take SPDIF/Optical Digital input and output Analogue Balanced XLR signal..... basically I'm after 2 channel DAC (24bit/96Khz), just want to get rid of ground loops and power supply noise (PC)... was looking thru trade me, no luck.
Or ATLEAST I will settle for SPDIF to RCA DAC, as long as it takes optical (say no to ground loops)....
Postby DeeCee » Fri Jul 22, 2005 12:46 am
you lucky i was loking for something similiar for my car :)
http://www.m-audio.com/products/en_us/CO3-main.html
GT Four Adovansu
DeeCee
Postby sergei » Fri Jul 22, 2005 9:19 am
Thanks man....
But this is NOT DAC...
Postby sergei » Fri Jul 22, 2005 9:21 am
Postby DeeCee » Fri Jul 22, 2005 1:12 pm
Doh - soz.. i was reading things too fast..
for a DAC you could go for a Rane, Behringer or as you have found the M-Audio - I like the M-Audio, simple layout, basic, cheap and does the job! :)
best of luck
GT Four Adovansu
DeeCee
Postby sergei » Fri Jul 22, 2005 11:00 pm
question is where I can buy those in Auckland??? (preferebly s/h)
Postby DeeCee » Sat Jul 23, 2005 12:16 am
http://www.elfa.co.nz/products_display.php?mfctr=MD
check at the electric factory or see if they can import it for you..
i don't think they have it in stock..
GT Four Adovansu
DeeCee
