Frequency Response
Frequency Response
Postby LEV_101 » Fri Aug 26, 2005 11:41 pm
hey everyone.
can someone explain what Frequency Response and sensitivity is ? is higher the better ? it is for speakers.
any help would be great. thanks
LEV_101
Postby SIKTOY » Sat Aug 27, 2005 9:09 am
Frequency response is :
the range (according to the manufacturer) of frequencies that the speaker can produce.
ie 18hz-2khz for a sub means the lowest frequency it can produce is 18hz (below the range of human hearing, but you can still feel it) and the highest frequency it can produce is 2khz. (which is quite high for a sub)
for a sub you want low frequency response
for a mid you want an average frequency response
for a tweeter you want a high frequency response
Note: human hearing is approximately between 20Hz to 20 Khz.
(depends on the person, those are usually the maximum though)
Sensitivity is:
measured in dB per watts per meter.
So if you had two speakers and you stood 1m apart from each and you put exactly the same signal (volume power etc) through them, the one with an 89dB sensitivity would be quieter than one with a 91dB sensitivity.
ie the higher the sensitivity the the louder it would be for the same powered signal. (according to the manufacturer)
Is this for interest sakes or are you comparing some speakers you wish to purchase?
ALL MEN DIE, NOT ALL MEN TRULY LIVE!
Current: 80 SR Project,
Check Out My Profile, Including CURRENT Pics!
Previous: 90 GT Sedan, 85 FXGT, 77 SR with 18RG, + many more.
Pink shaved pussy pic!!!
SIKTOY
Postby LEV_101 » Sat Aug 27, 2005 12:00 pm
hey. THANKS FOR THE HELP SIKTOY.
i am comparing speakers to purchase soon. do you have any idea what are some good 6.5" speakers to buy? i am currently thinking of rockford fosgates and pioneers. any ideas ?
LEV_101
Postby Alex B » Sat Aug 27, 2005 4:21 pm
whats your budget, where are they going? what is your current setup? :)
Postby LEV_101 » Sat Aug 27, 2005 4:31 pm
about 150 for a pair or speakers. i need both front and rear. blow 2 of my speakers when turned up loud :( ... currently have 6.5" in both front and rear. any ideas
LEV_101
Postby Alex B » Sat Aug 27, 2005 4:38 pm
wow dude thats a fairly limited budget, maybe just get some decent front speakers and forget the rears for now. http://www.parallelimported.co.nz/search.php?category=Speakers&main_category=Car%20Audio&mid=1&m2id=3&pos=3
nice set of JBL components for $150 mark there, youd probly find they still distory unless you amp them tho.
Just my 2cents. :)
