fuse
fuse
Postby scope » Thu Oct 06, 2005 12:39 pm
hello
i'm really new to car audio to hence this question. a mate of mine is going to borrow my amp (i haven't used it yet) and i don't want him blowing it, in his last setup he had just ran a power cable to his amp without any type of fuse and i'm pretty sure that it's best to put a fuse on that cable. so can anyone tell me what type of fuse to use that would be good!!
thanks
chicken fillet and bacon with everything except onion and bbq, ranch and southwest sauces
current ride: 1980 mazda rx7 series 1
previous rides: ke36 corolla, series 1 rx7, ke30 corolla, ke70 corolla x2
scope
Postby t0ms » Thu Oct 06, 2005 1:01 pm
fuse or circuit breaker within 30cm of the battery. and of a lower rating than the cable will sustain eg an 8 gauge cable will sustain approx 50 amps so a 40amp fuse would be good etc etc etc
easiest way is to go to repco an audio store or somewhere similar and get an amp install pack, they are usually not that expensive and they come with everything eg power cable fuse etc etc
t0ms
Postby Alex B » Thu Oct 06, 2005 7:39 pm
Im not saying your wrong t0ms but isnt 40amps a bit low?? That fuse is just in place for a dead short to earth is it not?
Postby wildchild » Sat Oct 08, 2005 1:23 am
get out ur amp manual it will have the correct fuse ampage in the wiring diagram
For Example My Sony XMD1000p5 (now has) 150A Blade Fuse (what it was sposed to have on there in the first place), to start off with i was running 30-60Amp fuses (factory 4gauge fuses) and i would pop them left right and centre so dont think its a good idea putting smaller 1's on there than what they suggest cause u will spend alot of money and time replacng the bastards, definetly fuse the power lead though
wildchild
Postby wildchild » Sat Oct 08, 2005 1:24 am
what is the make and model of your amp????
wildchild
Postby scope » Sat Oct 08, 2005 4:49 pm
e-audio 280ab
scope
Postby SIKTOY » Sat Oct 08, 2005 4:59 pm
you running all the channels at 4ohms?
ALL MEN DIE, NOT ALL MEN TRULY LIVE!
Current: 80 SR Project,
Check Out My Profile, Including CURRENT Pics!
Previous: 90 GT Sedan, 85 FXGT, 77 SR with 18RG, + many more.
Pink shaved pussy pic!!!
SIKTOY
Postby wildchild » Sat Oct 08, 2005 10:40 pm
wat sub r u running off that
wildchild
Postby wildchild » Sat Oct 08, 2005 10:45 pm
do not put any main power fuse bigger than a 40A on this amp (thats what the suggestion is in the manual)
wildchild
Postby SIKTOY » Sun Oct 09, 2005 8:30 am
That sounds about right for a 4x80 RMS amp.
Follow the manuals guidance.
Just use a 40A blade fuse right next to the battery and you'll be sweet.
Make sure its sealed from water though. (making the assumption your battery is still under the bonnet.)
SIKTOY
Postby Scoobydoo » Sun Oct 09, 2005 10:28 am
Yes a 40A fuse will be fine for this. In fact, it's what you should use, as that's what the fuses total on the amp itself.
Scoobydoo
Postby scope » Sun Oct 09, 2005 1:45 pm
ah sweet, cheers
scope
Postby Muzzie » Sun Oct 09, 2005 3:19 pm
SIKTOY wrote:That sounds about right for a 4x80 RMS amp.
Thats the 480AB, not the 280...............
Muzzie
Regular Poster
Postby Scoobydoo » Sun Oct 09, 2005 4:32 pm
Yeah.. what Muzzie said
Scoobydoo
Postby SIKTOY » Sun Oct 09, 2005 4:39 pm
Muzzie wrote:Thats the 480AB, not the 280...............
My bad, not thinking. :oops:
I'd only just woken up. See: Sun Oct 09, 2005 8:30 am
Early for a sunday morning after a late night.
SIKTOY
Postby t0ms » Mon Oct 10, 2005 12:23 pm
fuses are rated at what they will supply constantly eg a 40 amp fuse will supply up to 40 amps of current consistantly.
it takes roughly double to blow it... eg 80 amps to blow a 40 amp fuse..... an 80 amp dead short is a lot
t0ms
