headunit install
headunit install
Postby Victoria » Sun Oct 30, 2005 8:16 pm
Has anybody installed a HU into a 1993 trueno? i am having problems at the moment, for some reason the headunit will not recive power unless the ACC and 12v+ wires are both connected to the 12volt wire from the battrey, when i have the ACC conected to the approite wire from the car it dosnt seem to work? is there any soloution apart from running a new wire?
Thanks
Victoria
Postby Mr.Phreak » Sun Oct 30, 2005 8:24 pm
Checked your fuses?
Mr.Phreak
Postby nmemr2 » Mon Oct 31, 2005 12:28 am
ABANDON ALL HOPE
yea best bet, check your fuses and test the wires you are connecting before you do, make sure they are live
SW20, a work in progress for 2 years now, all i need to do now is work on it
nmemr2
Postby rallymazda » Mon Oct 31, 2005 8:22 am
ive installed HUs into several levins but i brought a plug that plugs into the factory harness, have you done this or just cut the plug off??
i will presume that the key is in the acc position first
secondly is there a constant 12v power coming from one of the wires??
[4AGE8U] << my old number plate
Got me a new altezza, now arrived
1991 corolla wagon- work hack
rallymazda
Postby gurutasker » Mon Oct 31, 2005 12:46 pm
Get a multi-meter and test the wire's that should be what they are, it's not hard to do by yourself without the factory plug, but if it's there it helps. How are you attaching the wires to the loom of the HU? Do you have some crimping clips? or a chocolate block?
:twisted: Wellington's TS Midget :twisted:
gurutasker
