2F2F subs + Infinity components?
Postby ben » Sun Nov 13, 2005 11:36 pm
I'm heading off to parallel imported tomorrow hopefully to get me some sounds for my gt4. The car has a JVC 50wx4 headunit - I want to get rid of the stock speakers and put components in the doors and a sub in the boot. I listen to stuff like eminem / papa roach / pink floyd (I R WHITEBOY).
I was going to get one of these subs either the FF110 or FF112. I know these aren't audiophile quality - but are they *okay*? I want my music to be tight with a bit of depth rather than boomy.
And then a set of components. I like these infinity 6000's - but would some alpines be better at the price (both are $190)? I used to have some clarion components ($90) and they were nice but far too bright - would the infinities be waaay better than my old clarions?
Finally - all those components are 6.5" and I've read the gt4 doorholes are 8" - what's the easiest way to build a spacer?
Thanks for your help. :)
White tshirt, black gt4. In the 04.
ben
Postby Alex B » Sun Nov 13, 2005 11:41 pm
those subs are utter crap man, but what do ya expect for $130 with an amp box and install kit :)
Postby ollieboy » Sun Nov 13, 2005 11:52 pm
I agree with pyro_sniper2002, I had that FF amp and it sucked, it just couldnt handle anything and it made my subs distort at 5 on my Head Unit and it goes up to 30. i didnt realise that kit was so cheap because I sold the amp to someone for $150. LOL. Thats Gold.
Anyway, sorry off topic. Yeah, I don't know much but i wouldn't recommend Lightning audio aye.
ollieboy
Postby ben » Sun Nov 13, 2005 11:56 pm
Ollieboy - that sounds a bit suss - you must have had your levels set wrong! :)
Anyone had good experiences with these kits? What else could I get in sub+box+amp for $300?
ben
Postby ollieboy » Mon Nov 14, 2005 12:13 am
ben wrote:Ollieboy - that sounds a bit suss - you must have had your levels set wrong! :)
Nah that was with the level right. I turned the HU up to 3/4 volume and then I turned up the gain until I heard distortion which I got almost straight away.
Thats the correct way to do it according to Blackrazor.
For $300 I got reccommended by someone, (I actually think it might have been Pyro) to get this:
Amp- Pioneer GM3100T Amp @ $149
Sub- Rockford Fosgate P112S4 @ $119
They are here:
Amp
Sub
Thats some real good stuff and I was going to get it but got a new car instead and it already had good sounds in it, cept for the FF amp, which I swapped for a Kicker amp which I would reccommend but they are a bit expensive.
ollieboy
Postby AJz » Mon Nov 14, 2005 1:15 am
ben wrote:Anyone had good experiences with these kits? What else could I get in sub+box+amp for $300?
as alex and most of us will say, there is a reason they are that price.
head on over to http://forums.nzicemag.co.nz/ and read up.
I had vtax :(
AJz
Postby ben » Mon Nov 14, 2005 1:28 am
Actually - i just went to the car and it doesn't have any door speakers - only door tweeters. Would it be worth buying the rockford-fosgate 4" components and mounting them in the dash location and the tweeters in the door - or would I be better off to buy 6.5" components and cutting holes in the door?
4" components
ben
Postby NZcelica » Mon Nov 14, 2005 5:29 pm
well i've got the infinity ref6000cs components and thats all the speakers I have apart from an infinity sub. And it sounds very primo (well to me anway)
If your holes are 8 inch. Go buy some 8mm mdf and cut it out to sit in the hole, then cut out a centre hole for the speakers. But you kinda want to secure the actual speaker to the door itself somehow
ST165 Celica GT-4 <SOLD>
97 GT-T 18psi <GONE>
96 Carib BZ 5 speed
Looking to import a car? PM me
Lots of performance Toyotas forsale. PM me for details
NZcelica
Postby AJz » Mon Nov 14, 2005 5:53 pm
you need to go at least 6.5 to get good sound,
having 4inch fronts, which will be you main speakers, (because you will want the music to come from the front) will just not be big enuff, plus the factory location points to your leg, which is useless, lol.
I had vtax :(
AJz
Postby blackie » Mon Nov 14, 2005 6:17 pm
Infinity 6000cs are pretty harsh.. but they complement a sub really good.
$&#$% that 2F bullshit.. buy some 2nd hand stuff
blackie
Postby ben » Tue Nov 15, 2005 12:27 am
Blackie and all you other dipshits - did any of you try the 2f2f gear? I've got a single 10" in my carnow and it rocks! $140, easy to install, easy to tune and works awesome for what I want.
Car audio snobs - what a breed. :P
Thanks for the other advice tho. I'm going to leave the factory 4" and components in for now.
ben
Postby Alex B » Tue Nov 15, 2005 12:28 am
No it doesnt rock at all you simply have no taste or shit ears :D
Postby AJz » Tue Nov 15, 2005 12:30 am
ben wrote:Blackie and all you other dipshits - did any of you try the 2f2f gear? I've got a single 10" in my carnow and it rocks! $140,
whatever makes you happy bud............
I had vtax :(
AJz
Postby Muzzie » Tue Nov 15, 2005 8:35 am
ben wrote:Blackie and all you other dipshits - did any of you try the 2f2f gear? I've got a single 10" in my carnow and it rocks! $140, easy to install, easy to tune and works awesome for what I want.
*cough*
You dunno sh!t then man.
Muzzie
Regular Poster
Postby NZcelica » Tue Nov 15, 2005 8:36 am
wasnt that 2f2f stuff made up with a 12 inch sub not a 10???
But anyway. I think ya next steep should be looking into some door components....like the infinitys 8)
96 Carib BZ 5 speed
NZcelica
Postby Alex B » Tue Nov 15, 2005 11:37 am
nah who needs infinitys man, get some 2f2f or lanzar comps :lol:
Postby CozmoNz » Tue Nov 15, 2005 11:51 am
Ignorance is bliss, its like the guy with the sohc civic telling everyone his car is faster than an Nsx, simply because hes never been in anything faster than his sohc civic :D.
Take their advise, when you hear what you purchase, youll be pleased, or you could continue living in a cave, and buy the 2f2f stuff.... But its your call... I mean if you really want cheap stuff, i know that jaycar do diy amps, and cheap as chips subs... could probbaly get a whole system in there for under $100 ;).
Rayne For President!
CozmoNz
Postby DeeCee » Tue Nov 15, 2005 12:25 pm
can't get a system under $100 at jaycar..
spend a little more and get some better quality gear.. it's what it comes down to :)
GT Four Adovansu
DeeCee
Postby CozmoNz » Tue Nov 15, 2005 12:29 pm
Soooo can... wont be any good, and will be paper speakers, Ive got the cost price book right here...
theres plenty of DIY stuff in there :D. make your own 30w amp sort of thing.
CozmoNz
Postby DeeCee » Tue Nov 15, 2005 2:28 pm
after wiring, connectors, amplifier, speakers, subwoofer - no you can't get a system for under $100 unless its of the lower quality that you speak of and i do know as i go in there enough and have a friend who works there.
suffice to say, spend the money wisely and get a decent system that will last and go well
response kevlar splits, a nice response 4 channel amp, a carbon 10" sub and some midrange coaxials for the rear and you're good to go :)
GT Four Adovansu
DeeCee
