ST20X Celica stereo setup
Postby RunningRich » Thu Nov 24, 2005 8:01 pm
I have splashed out on an Alpine 9833 to replace my ooooolllld panasonic stereo.
I'm still running factory speakers and being nz new there are only four. With only 8" front and no high mounted tweeters the soundstage (?) needs lifting.
I'm planning on improvements, and have read the thread about available 8" drivers. I will definately get the factory tweeter mounts. Is it also worth getting door cards with the 5.25" mids?
With decent 5.25" components at the front (run off headunit) and 6.25 two way in the rear (run off headunit), should I then get a small 2 chnl amp to run the 8" driver in the front for base? As it is the doorcards buzz something wicked so sounddeadening is also needed.
Suggestions?
I *don't* want visible amps or a boot sub. This is not for competition, just I like reasonable sound.
Richard
http://gtfour.supras.org.nz
RunningRich
Postby DeeCee » Thu Nov 24, 2005 11:59 pm
replied on ice :)
GT Four Adovansu
DeeCee
Postby Adydas » Fri Nov 25, 2005 10:04 am
anyone know if the ST185 lays out the same? it sounds close. as thats about what my plans extend to ( just 4ch amp and run rears off it to. )
Adydas
Postby DeeCee » Fri Nov 25, 2005 6:48 pm
do you have system 10" or normal audio setup in celi?
GT Four Adovansu
DeeCee
