sony CDXMP50 head unit wiring
Postby l1ttle_d3vil » Mon Dec 12, 2005 6:25 pm
I've got a CDX MP50 head unit I need to wire up. Can anyone identify the colour wires for me please? I don't have a diagram and can't find any info on the net...
This is an older unit, 2004 model I think.
thanks.
* White - Speaker
* Green -
* Purple -
* Grey - Speaker
* Blue/White - Has "AMP REM MAX 0.3A" sticker on it
* Blue - Has "ANT REM MAX 0.1A" sticker on it
* Red - IGN +? Can anyone confirm this?
* Black - Earth
* White/Black - Speaker
* Green/Black
* Grey/Black - Speaker
* Purple/Black
* Light blue - Has "ATT" sticker on it
* Yellow - Batt? Can anyone confirm this?
Postby AJz » Mon Dec 12, 2005 6:58 pm
yellow = batt
red = ign
black = ground
normal blue = antena power
blue/white = amp power
white & white/black = front speaker (pos & neg)
grey & grey/black = front speaker (other one, pos & neg)
purple & purple/black = rear speaker (same as above)
green & green/black = rear speaker (same as above)
light blue = not sure
I had vtax :(
AJz
Re: sony CDXMP50 head unit wiring
Postby Mr.Phreak » Mon Dec 12, 2005 7:04 pm
* White - FL +
* White/Black - FL -
* Green - RL +
* Green/Black - RL +
* Purple - RR +
* Purple/Black - RR -
* Grey - FR +
* Grey/Black - FR -
* Blue/White - Remote Power
* Blue - Aerial Power
* Red - ACC
* Black - Ground
* Light blue - Mute
* Yellow - Constant +12v
Mr.Phreak
Postby l1ttle_d3vil » Mon Dec 12, 2005 10:32 pm
thanks for that. just two Im still not sure of.
* Light blue - Mute? Whats that for? Is that so it mutes when you press that on the remote or what? If so, I don't have a remote so won't bother with that.
* Blue/white - remote power or amp power?
Postby Alex B » Mon Dec 12, 2005 10:47 pm
mute is for connectiong to a wired in phone etc, or you can wire it to a mute switch, can be quite handy :)
Postby l1ttle_d3vil » Mon Dec 12, 2005 10:59 pm
so basically I can wire it into a switch that I can flick if I want to mute the stereo? how does it work? does it just need to run to an earth or something?
Postby Alex B » Mon Dec 12, 2005 11:05 pm
yeap run it to an earth.
