Head deck help..
Head deck help..
Postby glanza_rolla » Mon Jan 23, 2006 9:41 pm
I've got a head deck in my car that came with it from japan..I put a CD in and it reads it but the volume doesn't work.. :?: ...only when its trying to play a cd :?: ...anyone had that..and can it be fixed..help would be appreciated...churr
glanza_rolla
Postby glanza_rolla » Mon Jan 23, 2006 10:21 pm
it reads the cd but no volume...any help?
glanza_rolla
Postby snwtoy » Mon Jan 23, 2006 10:21 pm
Make/model?
Does the car actually have speakers?
snwtoy
Postby Jazza » Mon Jan 23, 2006 10:21 pm
*EDIT* Misread your post...
Heres my ideas.
1. Check the wiring, maybe faulty or not wired correctly.
2. Check your speakers, test them to make sure theyre not blown.
Ill add them as they come to me
1996 Curren - On Tardme
Jazza
Postby glanza_rolla » Mon Jan 23, 2006 10:23 pm
Yes the car has speakers...and its not a stock stereo its an aftermarket...quite nice head deck..
glanza_rolla
Postby Jazza » Mon Jan 23, 2006 10:24 pm
Has it got a brand name? Give us a discription?
Whats it play? Are you sure there isnt some random stupid "buttom lock" so you cant bump your head deck? Just trying to rule stuff out
Jazza
Postby glanza_rolla » Mon Jan 23, 2006 10:24 pm
Jazza wrote:*EDIT* Misread your post...
Heres my ideas.
Hmm...would they be blown..if the radio is on you can actually hear it..
glanza_rolla
Postby snwtoy » Mon Jan 23, 2006 10:28 pm
Take a photo of it? Must be a make/model on it somewhere. Although I've never heard of a cd player that didn't work for pretty much every cd... You're not trying to play burned cds are you?
snwtoy
Postby glanza_rolla » Mon Jan 23, 2006 10:31 pm
Ive tried copied CDs..and original CD's both didnt work....
Here is a photo..
glanza_rolla
Postby Jazza » Mon Jan 23, 2006 10:32 pm
Could be a fault IN the head deck. Not sure how they are internally wired but is it possible that while on CD the volume control isnt able to be used. Is your head deck like mine, where if i set the volume to 50 on radio, and switch it to cd and set cd volume at 10, then switch back to radio its on 50 again? Or is it 1 volume for the entire time?
Jazza
Postby glanza_rolla » Mon Jan 23, 2006 10:34 pm
I cant even hear the CD if it's on Max volume :?:
glanza_rolla
Postby snwtoy » Mon Jan 23, 2006 10:34 pm
Could it be (far fetched maybe) that the cd player is set to not use the internal amp - ie output through rca's only?
What's the brand name/model?
snwtoy
Postby Jazza » Mon Jan 23, 2006 10:34 pm
But radio works?
Jazza
Postby glanza_rolla » Mon Jan 23, 2006 10:35 pm
Yess radio works :? but for some reason it reads the CD's but no volume..
glanza_rolla
Postby snwtoy » Mon Jan 23, 2006 10:37 pm
snwtoy wrote:What's the brand name/model?
snwtoy
Postby glanza_rolla » Mon Jan 23, 2006 10:38 pm
Eclipse...
glanza_rolla
Postby Jazza » Tue Jan 24, 2006 8:15 am
Did some reading, does it look like the original face unit? And its not detachable correct? Apparantly they will show problems your having if its not the original head unit. Ill keep reading about them
Found this on some "car sound and performance forums"..
"Well after years of faithfull service my 8061 has developed a problem. I just moved it to it's third car and now it won't play CD's. Radio still works fine, and everything else seems to be fine, but when I put in a CD i can hear it ever so quietly trying to spin up over and over again, but the volume wont adjust. I love this deck and don't want to have to give it up. How much is Eclipse getting for repairs these days (I'm out of warranty)? Any suggestions on what I might try myself? I think it's probably pretty dirty inside, might it just need a clean out?
thanks a ton"
Apparantly there was no resolution to the problem.
Jazza
