Advice / help ( non car related Audio / Visual question)
Postby Adydas » Sun Mar 19, 2006 12:57 pm
Decided to buy a Projector as a TV with the order of a XBOX 360 due in less than a weeks time.
And what i want to know is whats the best way to get TV signal into an RCA / SVID input.
I have a TV Cap card in my pc how ever means wires everywhere, there might be a simpler version out there.
Anyone know anything that can help me? ( other than using Sky Digital )
heres some pics, Highly reccomend. ( not the best light / camera conditions but non the less Fantastic pictures )
Adydas
Postby tomo1985 » Sun Mar 19, 2006 5:08 pm
You could plug a VCR in and use that to pick up the tv signal.
tomo1985
Postby Adydas » Sun Mar 19, 2006 6:57 pm
i considerd that but the vcrs around here dont have a RCA out or nething so it wont work.
And i dont want to buy a new unit just for this, unless i had to.
Adydas
Postby Sideros » Tue Mar 21, 2006 10:50 pm
Try getting a sony TV tuner, an attachment for the in car screens. I'm not sure if these units have RCA output however, might have some proprietary connections however. Could be worth a look?
Sideros
Signwriter
Postby ollieboy » Wed Mar 22, 2006 1:01 am
You just want to show off that you got a projector. :P
I think I get what you mean but am not too sure.
We have a similar setup at home and we have a svideo cable from pc tv card to projector. Its quite an expensive cable sometimes but its good because its just the one cable and its good quality.
On second reading I'm still not sure if thats what you are after but its the only way I know of and we hide the cable under the carpet so theres no wires on the ground.
I also know of a thing similar to the pc tv card.
found here:
http://www.dragonpc.co.nz/p.aspx?48102
and here
http://www.dragonpc.co.nz/p.aspx?72600
sorry, its the only website I know with them on and I can't be bothered searching but at least its in NZ.
edit: oh and you don't need a pc for these I believe.
ollieboy
Postby ollieboy » Thu Mar 30, 2006 5:28 pm
So what did you work out in the end?
ollieboy
Postby Blackrazor » Thu Mar 30, 2006 6:03 pm
A cheap VCR is going to be far and away the best way to do it. Look for a 2nd hand 6 head VCR on Trademe, one with f*cked heads is fine as you only want to use it for the tuner :)
Boring Sig
Blackrazor
Postby Sideros » Mon Apr 17, 2006 10:34 pm
Hmm thats a good idea, wonder how that'd go with an inverter in a car...!
Sideros
Signwriter
