amplifier cutting off
Postby dvsLEVIN » Tue Mar 28, 2006 12:32 am
hey guys.. a question about my amp.. i got a 760w max pioneer amp and am running an alpine type e 12inch sub off that.. but when i crank up the volume too much the bass just turns off and comes on in a while and then turns off again ?!?!.. can anyone tell me why it is that that happens and what is needed.. would installing a capacitor solve the problem ??
dvsLEVIN
Postby Alex B » Tue Mar 28, 2006 12:39 am
Cap will do sfa. Check your earthing. and dont deal with max ratings either, as they mean nothing :)
Postby dvsLEVIN » Tue Mar 28, 2006 12:46 am
cap will do sfa ??? what does sfa mean ??.. yeah and the amp is 380w rms.. i think the earthing should be fine cos it was a professional installation job.. but i'll check..
dvsLEVIN
Postby Alex B » Tue Mar 28, 2006 12:47 am
sfa means sweet fu ck all.
Postby 86_rolla » Tue Mar 28, 2006 8:09 am
could it be the amp protection light thingy?
Current: EF Honda civic
Ex cars: 2E corolla
http://toyspeed.blakjak.net/profiles/pr ... hp?id=1488
86_rolla
Postby Jazza » Tue Mar 28, 2006 8:14 am
My subs did it too, except my entire stereo would shut down for a min or 2. Does your amp have a HPF and LPF switch you cn change? Cos all i had to do was turn off the HPF switch on mine and it stopped doing it
Jazza
Postby WeNdY^cLeAr » Tue Mar 28, 2006 8:18 am
Isn't it just like a protection thing?
So they don't overheat and blow up?
My Rockford amp did it a couple of times in summer last year when I had it up quite loud.. I just let it cool down and it was fine again..
WeNdY^cLeAr
Postby Santa'sBoostinSleigh » Tue Mar 28, 2006 9:27 am
check your amp isnt overheating and therefore going into protect mode
Santa's Mega Sale
Santa's TardMe Listings
GTFX: viewtopic.php?t=67655
Postby Blackrazor » Tue Mar 28, 2006 10:49 am
... and turn the gains down. Gain is a sensitivity setting, not a volume knob.
Boring Sig
Blackrazor
Postby DeeCee » Tue Mar 28, 2006 10:52 am
amp is cutting out when it goes into protection mode.
Check: power wire (guage, termination, fusing), ground wire (grounded to chassis of car and sanded back ground point, adequate guage wire), and possibly battery (battery may be too small ie a 300CCA battery is rather pitiful for an upgraded stereo system). Also, check gains on amplifier (gains may be set too high and cause clipping to occur pusihing amp into protect).
Capacitor may help but will eventually be a large paperweight/bandaid in the future if you intend to fix your problem correctly.
Position of the amplifier relative to open air is important as well.. think intercoolers.. you need air flow to get best performance, same with amplifiers.. air flow cools down internal components providing a better operating environment to work in. If you amp is smothered somewhere example between the seat and the box then i'd say that you'd best to move to provide ventilation. Same goes for mounting upside down, or close up underneath parcel tray
GT Four Adovansu
DeeCee
Postby dvsLEVIN » Wed Mar 29, 2006 7:24 pm
shot guys.. thanx for the help.. yeah i think it's going into protection mode cos my amp does get really hot cos its actually between the seat and the box.. will try to get sum air flow there.. and the gain is set at like less than halfway.. so yeah..
dvsLEVIN
Postby Zyros » Wed Mar 29, 2006 11:37 pm
dvsLEVIN wrote:shot guys.. thanx for the help.. yeah i think it's going into protection mode cos my amp does get really hot cos its actually between the seat and the box.. will try to get sum air flow there.. and the gain is set at like less than halfway.. so yeah..
The remote wire on the head unit could be loose.. does the amp turn off completly? If it has a power light, watch if it flashes.
Zyros
