Dynatron alarm manuals?
Postby snwtoy » Fri May 19, 2006 9:27 pm
I have a dynatron alarm in my new wee beasty (came with it). It's an older model with the red led instead of a blue one.
I'm hoping that when I take the dash apart I'll find the brain this weekend, and there'll be a model number somewhere on it.
If this is the case, are there manuals available? I really want to disable the blimmen auto-arm and enable central locking.
Cheers!@
snwtoy
Postby samlloyd » Fri May 19, 2006 10:02 pm
Isnt the red led newer then the blue led models?
samlloyd
Postby bluemaumau » Fri May 19, 2006 10:29 pm
i have a red led and got mine in 2004 november. if it helps
Postby Sick Puppy » Sun May 21, 2006 5:38 pm
Purchased my dynatron in July 2005- has the red LED- hope I didn't get stuck with old stock...
Sick Puppy
Postby BlakJak » Sun May 21, 2006 7:48 pm
Got mine late 2004 with a Blue LED.
It was a current model at the time......
BlakJak
Postby snwtoy » Sun May 21, 2006 8:09 pm
Blue LED is definitely the newer or higher end models in my experience, otherwise the installer could be swapping it to keep the blue led for himself.
snwtoy
Postby bluemaumau » Sun May 21, 2006 9:14 pm
$&#$% i dont really care about my alarm any more eh.
if they want it theyll take it :cry:
Postby t0ms » Tue May 23, 2006 9:31 pm
red led is a 3 series alarm (standard type system) push remote button to turn immobilisers off
blue signifies 7 series alarm system. transponder in remote turns immobilisers off for you.
the case wont give you a lot, it will have a generation code on it and a build date.
ring dynatron on 0800 508 904 and talk to the operator there, they will have your car on record hopefully and will be able to tell you what it is
tom
t0ms
Postby snwtoy » Tue May 23, 2006 9:38 pm
t0ms wrote:red led is a 3 series alarm (standard type system) push remote button to turn immobilisers off
tom
Thanks, was waiting for your input :) Helpful as usual :)
snwtoy
