uniden alarm
uniden alarm
Postby Cakky » Tue Sep 26, 2006 6:16 pm
hey guys
having problems with the glass break sensor on my uniden alarm
when it was first put in, you could tap on the glass with a key and it would go off sweet as, however i found it was too sensitive and i turned it down a little bit and it didnt work at all, turned it back on full, still didnt work.
got a new glass break sensor ( the box part ) and put that in and worked fine for a few hours now it doesnt appear to be working again
do you think possibly the microphone ( the thing that is on the windscreen that picks up the sound ) could be faulty?
any ideas much appreciated thnx
1989 Corolla GT sedan blacktop 20v
Cakky
Postby fuel » Tue Sep 26, 2006 6:35 pm
Yeah I would like to know as well.
I have a uniden alarm with glass break sensor too, and when I tap on the glass with keys or even bang on the glass it doesn't even go off. I just hope it goes off if the glass gets broken. Mine's set at max sensitivity.
LOUD NOISES!!!
fuel
Postby Cakky » Wed Sep 27, 2006 5:31 pm
are you finding that it will go off sporadically?
mine goes off in wind, rain, but wnt go off when i tap the glass with my keys
also set at max sens... :?
Cakky
Postby fuel » Sun Oct 08, 2006 5:24 pm
Nah my alarm is good like that - it doesn't seem to false alarm unless my flatmate drives her car next to it :roll:
I have the first alarm set at medium sensitivity, and the main alarm at low sensitivity. If you kick the wheel it will chirp usually, and if you boot the wheel it will go off. I just can't get it to do the same with the glass sensor tapping on the window.
LOUD NOISES!!!
fuel
