DeeCee wrote:
if you have a broken bulb then alarm won't go off.
alternatively the installer could just be lazy and is blaming the car instead of finding the problem and getting the alarm to work properly..
A blown bulb will not stop the alarm going off. The alarm is wired to the switch that activates the light, no through the light.
Quite often in boots the latch / switch gets all gummed up with crap and won't function. Try spaying out the latch with CRC or similar. Quite often a new switch is needed though. You may have to pay the installer for his time to investigate this further.
Deno wrote:Yep, in that order![]()
Stick to audio DeeCee.... it's less stressful in the long run ..
HERGTT wrote:You got me a bit worried with this post, just went to check mine...
when I open the boot, the door sensor light DOES come on![]()
all good
all good
