URGENT: Speaker help please,car to be sold tomorrow
Postby suped » Sun Feb 25, 2007 8:46 pm
My 2003 Corolla had Alpine Type R components infront and the right speaker used to always phase in and out.
Most of the time it worked but yeah sometimes it just crackled.
I uninstalled and replaced with the original speakers and headunit today, that right speaker does not work at all.
This surely must be a wiring problem? How would you go about fixing this?
I would really appreciate some help!
Thanks guys.
Aaah no more Corolla..
suped
Postby Alex B » Sun Feb 25, 2007 8:49 pm
check the connections at the headunit and the speaker would be a real good start :)
Postby suped » Sun Feb 25, 2007 8:50 pm
Haha yep, theyre seemingly all good.
Must be somewhere inbetween.. but how the hell to check that :(
suped
Postby bluemaumau » Sun Feb 25, 2007 9:04 pm
run new wires
Postby Alex B » Sun Feb 25, 2007 9:07 pm
Easier said than done, i dono, you havnt exactly given us alot to work with. Pretty much just process of elimination, ie is the wire ok? Is the speaker ok? Is the headunit ok?
Postby suped » Sun Feb 25, 2007 9:11 pm
I think the wire's pretty shit because it wasnt working 100% before.
But dunno.
How much would an auto electrician charge to run new wires?
We've done all the hard stuff and taken the components and amp out so might as well pay.
suped
Postby Alex B » Sun Feb 25, 2007 9:13 pm
Depends on how cunty it is to put in.
Postby suped » Sun Feb 25, 2007 9:14 pm
Shit true.. like $50? Or are we talking like an hours work?
suped
Postby Alex B » Sun Feb 25, 2007 9:16 pm
Dude it really depends, he could have to take half the dash out and take the door off or it could be a 5 min job. You don't even know for sure if it is the wire.
Postby suped » Sun Feb 25, 2007 9:24 pm
Yeah fair enough, I'll see how it goes.
Cheers man.
suped
Postby matt dunn » Sun Feb 25, 2007 9:57 pm
I presume the speaker is in the drivers door?
They break the wiring thru the door.
We do them quite often at work.
Options are to
Run a new wire across the gap on the outside - ugly and visable but works and is cheap.
Run a new wire through the existing grommet - takes time and can be fiddly, sometimes you have to take out 1/2 the loom from the car end, and sometimes it doesn't work at all.
Remove the whole door loom and replace the wires through the door shut.
- expensive and time consuming but the best option, you dont know how many other wires in there are about to break aswell.
Postby suped » Sun Feb 25, 2007 10:07 pm
Oh, thanks so much for the in-depth reply man.
It probably is broken through the door.. well I have a fun day ahead of me tomorrow then.
Taking the bloody headunit was a pain in the arse, the centre console is so terrible in these things.
suped
Postby big_boy » Mon Feb 26, 2007 7:55 am
also you can always put a muilty meter on ohms between the wire & the H.U & the wire @ the door to see if its the wires or the speaker its self
for sale EE90
big_boy
Postby GTCRSHR » Mon Feb 26, 2007 11:56 am
Just pull the head unit out and run a wire from which ever side isnt working to the speaker, if it springs into life then its pretty obvious that its the wire,
if its not then its either the speaker, check with another speaker
or the head unit, replace the headunit
pretty simple
Nothing to see here ...
GTCRSHR
