Hi there, am looking for a new alarm for a new car, have spied an AVS S5 which says it has a turbo timer interface, Does this mean if you have a pre existing turbo timer you can set it up to be able to run while the car is alrmed etc? Is it hard to install/use this feature?
Is it hard to set up, the aforementioned alarm is 5 star rated, and I can get one for $280, I have a few sources that I get get it installed at, But does anyone know a better, around the same price or cheaper alarm system? The more stars rated the better
