by cynakyl » Tue Aug 07, 2007 11:38 pm
It will run them but it wont sound the best, ideally you want to match the rms or have the amp output slightly higher than the rms of the sub, that way when you crank it and the sub needs to go hard the amp isnt struggling to keep up therefore possibly damaging both... if you can find a single channel amp that will output 800w rms @ 2 ohms would be pretty much bang on if you ran the subs in parallel. Actually, whats the single channel output of that amp and does it list a 2 ohm output?
Driving a honda is like being in the special olympics. Even if you win, you're still retarded...
