why PM me?
and don't listen to pjay and his sand rant = bad idea! (i keep telling you PJ
anyhoo..
mass loader, dampening, barrier, absorption - whats your flavour?
if you trying to cut down on road noise, then we should be looking at barrier/dampening and absorption.
Dynamat is barrier and dampening. Will decrease noise by creating a barrier that noise has to get through and transfer noise energy to heat (apparently)
Foreman insulation have a couple of different materials for noise reduction, but overall, DX would be easy for you to obtain and buy over other different materials that require a bit more installation thought over peel and stick.
if you are on budget and want to save weight.. at least cover areas near the wheels - front foot wells and rear arches to minimise noise from tyre contact with road
