ported box is better overall
better sounding, louder and lower resonance.
The sub should only do below 80hz, and concentrate around 20-30hz.
back in the day I made an ABC box for myself and eric (dodgeviper on NZICE). They used to pump hard but are more difficult to make and get right (still easy if you have half a brain). They were for Digital Design subs.
I just put all the sub parameters into WinISD and play around with box sizes and port lengths. Compare the difference between sealed box and ported box
Ideally you want to sub fs as low as possible and match the box (encloseure and port) resonance to the sub fs.
