avs s5 problem
avs s5 problem
Postby devius » Sat Nov 24, 2007 4:37 pm
my car has a avs s5 alarm with extra functions such as tilt sensor and internal screamer siren, the core unit works fine lock unlocks, shock sensor works, unlock doors while alarmed siren and lights go but the tilt sensor is not doing anything and the internal screamer randomly started hissing constantly yesterday and the back up siren unger the bonnet is very very very quitely sounding
any thoughts???
devius
Postby Deno » Sun Nov 25, 2007 11:11 am
Are you sure you a jacking the car up enough to set the tilt off? You need to get the wheel off the ground normally.
Sounds like you have lost an earth on the sirens. A bad install may have caused this or even corrosion etc. Find where the sirens are earthed and clean it up/ redo it etc.
You're just jealous the voices are talking to me!
85 MR2 NA faded red
86 MR2 Supercharged
90 Starlet GT (sold)
93 AE101 Levin parts car (PM if you need anything!)
97 Carib Sprinter (sold)
Deno
Postby gleem » Sun Dec 09, 2007 12:36 pm
what did the problem turn out to be? how many degrees is your tilt sensor set at? thinking of getting one as well for my s5
gleem
Postby devius » Tue Dec 11, 2007 5:01 pm
cae is going back to the installer to figure out problem so will let ya no when i do
thanks
devius
Postby AJz » Tue Dec 11, 2007 6:04 pm
when you lock and unlock it, it beeps rite, is that the same volume as it usually is ??
Hard to tell what it is, could be earth.
Have you been under the dash / engine bay lately that may have moved / bumped wires ???
I had vtax :(
AJz
Postby devius » Tue Dec 11, 2007 7:24 pm
yeah normal volume on lock/unlock
nah i havent been under anything aye
devius
Postby AJz » Thu Dec 13, 2007 12:29 pm
hmmmm thats real wierd....
yea take it back to the installer and see what they say.
I had vtax :(
AJz
