Runx/Allex stereo aerial power?
Postby snwtoy » Mon Feb 02, 2009 8:52 am
Hi folks
For anyone who has replace teh stereo in a runx/allex can you tell me which wire is the aerial power?
Reception with my new stereo is absolutely rubbish, and I'm pretty sure there was a wire I needed to give power to to fix this last time I had this problem.
Cheers!
snwtoy
Postby Alex B » Mon Feb 02, 2009 9:07 am
Have a feeling its the pink wire, assuming it uses the same as the electric aerial.
Postby mr30%jr » Mon Feb 02, 2009 9:23 am
wheres a little white spade plug which runs along with the aerial thats if its a window mounted one. that usually loops back into the loom with yea i think its a pink wire
mr30%jr
Postby snwtoy » Mon Feb 02, 2009 10:20 pm
It's not a window one, it's one of the stubby roof mount ones.
So I need to find the pink wire, and give it 12V acc power yes? Just splice into the existing acc power wire?
What's the best way to test I have the correct wire? Don't want to go blowing fuses :S
Cheers :D
snwtoy
Postby DeeCee » Mon Feb 02, 2009 10:26 pm
why aren't you using loom adaptors? normally that is the easiest solution to put a stereo in a car.
GT Four Adovansu
DeeCee
Postby snwtoy » Tue Feb 03, 2009 9:25 am
DeeCee wrote:why aren't you using loom adaptors? normally that is the easiest solution to put a stereo in a car.
What's the point of a loom adapter if I only hook up power, acc and earth?
snwtoy
Postby DeeCee » Tue Feb 03, 2009 10:33 am
because you need to hook up the aerial as well it seems.
generally its the pink wire twisted up to a black/red wire for power aerials
12V + = Blue w/Yellow stripe
Ignition = Grey
Ilumination = Green
Ground = Brown
Aerial = Pink + Black w/red stripe
L front = Pink+ / Purple -
R front = light green+ / blue-
L rear = black+ / yellow-
R rear = red+ / white-
GT Four Adovansu
DeeCee
Postby rodstr » Tue Feb 03, 2009 9:10 pm
oh... i dont even remember hooking this wire up and it seems to be fine, I should take another look :?
rodstr
Postby snwtoy » Tue Feb 03, 2009 10:10 pm
rodstr wrote:oh... i dont even remember hooking this wire up and it seems to be fine, I should take another look :?
Ours "works", it's listenable, but you need to turn it up a long way, and it's a bit patchy.
If you didn't connect it you could be missing out. But then again, I've removed a shedload of other boxes and cabling that went with the original stereo - if you didn't do that you might be ok :)
snwtoy
