where to mount cross over?
Postby deaf_rattle » Tue Aug 04, 2009 4:54 pm
Is it better to have the cross overs for the component speakers closer to the amp, or closer to the drivers?
Postby GTCRSHR » Tue Aug 04, 2009 5:18 pm
doesnt make any difference
Nothing to see here ...
GTCRSHR
Postby Snaps » Tue Aug 04, 2009 6:34 pm
Wherever they fit best :lol:
Might want to make it easily accessable as well, just makes it easier to set up.
Cheers,
Brandon
2000 ZZT231 Manual Toyota Celica
Snaps
Postby postfach » Tue Aug 04, 2009 6:36 pm
I would mount them a close to the drivers as possible, not for any technical reason, but simply because then you end up using less cable, that said, somewhere practical where you can get at them reasonably easily if you have to is a good idea.
postfach
Postby jakesae101 » Sat Aug 08, 2009 12:34 pm
on my car i mounted one on the passengers side kick plannel and the drivers one is tucked up under the dash
EX. MK2 escort 4 door 1300cc
EX. AE101 trueno gt apex
jakesae101
Postby Emperor » Sat Aug 29, 2009 2:48 am
what speakers? as some crossovers arnt ideal to put on the doors.
fusion lomus are quite weak around the joins, slamming doors shut can cause the parts to go loose
Emperor
