battery in boot question
Postby deaf_rattle » Fri Jul 09, 2010 7:38 am
I have the battery mounted in the boot with a 140 amp circuit breaker inline with the 1 gauge from battery to starter motor.
Been talking to the guy who rebuilt my alternator and he reckons i shouldnt bother with c/b inline to the starter, but maybe run one from the power cable from starter motor to dist block (feeds alt and other engine bay power feeds)
He said if i wanted anything inline, i should just run a kill switch.
thoughts?
Postby DeeCee » Fri Jul 09, 2010 8:28 am
read my battery relocation tutorial..
GT Four Adovansu
DeeCee
Postby eskimo » Fri Jul 09, 2010 8:45 am
Id go for the kill switch option and leave the CB out
"If in doubt, flat out" Colin McRae 1968-2007
Current:2003 Legacy 3.0R Spec B
Previous: ST185 GT4, SW20 MR2, ST206 Curren, AE111 Corolla GT
eskimo
Postby Malcolm » Fri Jul 09, 2010 9:36 am
I wouldn't want cable cable of carrying the current that 1awg can running 4m through my car from a power source without any short-circuit protection. I'd definitely be keeping the circuit breaker
Postby XS1V » Fri Jul 09, 2010 10:05 am
Dont go kill switch if you have or a getting an alarm, just doesnt work
Brad
ST205 Group A Rallye #2363
XS1V
Postby Crampy » Fri Jul 09, 2010 11:21 am
I ran a CB for my battery in boot setup.
I only used a 100 amp from memory. It was fine the entire time I had the car.
Crampy
Postby tsoob » Fri Jul 09, 2010 11:51 am
i run the cable straight to the starter and a terminal block, have had 0 problems
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
WHEELS, TYRES & SUSPENSION!
www.platinumwheels.co.nz
tsoob
Postby Malcolm » Fri Jul 09, 2010 1:42 pm
plenty of people will run without any sort of fusing in their cable and never have a problem, just like how many people in the US ride motorbikes without helmets but never die from head injuries because they haven't crashed yet.
When you have a cable capable of carrying significant current, and this cable is connected to a car battery, if you somehow wear through your insulation - be it chafing at a firewall pass-through, something sharp/heavy being placed on top of the cable, or even an accident that causes the insulation to be cut, you'll have several hundred amps running through that cable, and it can get very hot, easily hot enough to start a fire. There are a few documented incidents on forums of people who have lost their pride and joy because it burned to the ground after a fire caused by a battery cable shorting.
Not worth the risk IMO when a fuse or circuit breaker is only $20-50
Postby Bling » Fri Jul 09, 2010 1:52 pm
Yeah madness to not fuse it 8O
