running 2 amps
running 2 amps
Postby 88.4ageGT » Wed Oct 06, 2010 1:17 pm
ino this a simple qestion but
if i wanna run two amps do i just split the rca cable then run one to each amp?
AE92 4age GTi
Building 3sge ae92 race car
Malcolm wrote:I didn't know they had maths on waiheke
88.4ageGT
Postby soopachargen » Wed Oct 06, 2010 1:18 pm
how many rca outputs does your headunit have??
When in doubt, down and out.
soopachargen
Postby 88.4ageGT » Wed Oct 06, 2010 1:27 pm
it doesnt have any. i brought
a speaker wire to rca converter
and wanna run to 2 amps
one for a sub and one for speakers
AE92 4age GTi
88.4ageGT
Postby soopachargen » Wed Oct 06, 2010 1:30 pm
in that case yep, just split the rca and run to each amp, you just wont have very good control with the headunit, but having no rcas you wouldnt have had to start with.
otherwise you could get two line level converters and run front speakers off the front speaker cables and the sub off the rears, that way you can tune it a bit with the fader control on the headunit
soopachargen
Postby 88.4ageGT » Wed Oct 06, 2010 1:34 pm
thanks
um next question can you explain whats the difference between a 1 channel amp and 2 channel?
AE92 4age GTi
88.4ageGT
Postby soopachargen » Wed Oct 06, 2010 1:38 pm
each speaker runs off a channel, a one channel amp or mono amp in its most basic configuration will run a sub, a two channel amp will run a left and a right speaker, so you have a left channel and a right channel. With a four channel amp you have a front left, front right, rear left and rear right channel.
Hope this makes sense?
soopachargen
Postby 88.4ageGT » Wed Oct 06, 2010 1:46 pm
yea i get that
so the amp i have has this on it
speaker
so is that a 2 channel?
and which two of those four do i connect the sub to?
AE92 4age GTi
88.4ageGT
Postby soopachargen » Wed Oct 06, 2010 1:51 pm
that would be a two channel amp
12volt direct current, as used in a car travels from positive to negative, so it runs from the + terminal of the amp, to the + terminal of the speaker, through the speaker's coil to the - terminal of the speaker, back to the - terminal of the amp.
What brand and model are your sub and amp? Most amps are bridgeable, which lets you run from the positive of the left amp channel to the sub and then to the negative of the right amp channel "bridging" the amp, this will give you more power into the sub.
soopachargen
Postby 88.4ageGT » Wed Oct 06, 2010 1:53 pm
ok so with that amp i could run 2 subs?
AE92 4age GTi
88.4ageGT
Postby soopachargen » Wed Oct 06, 2010 1:56 pm
in theory you could run two subs off it, but I would guess that that amp wouldnt be putting out a huge amount of power, you are much better off running one sub with enough power than two subs underpowered
soopachargen
Postby 88.4ageGT » Wed Oct 06, 2010 2:00 pm
so if i wanna have 2 subs nd 4 speaker
i need
two 2 channels amps (for the subs)
and
a 4 channel amp (for the speakers)?
AE92 4age GTi
88.4ageGT
Postby soopachargen » Wed Oct 06, 2010 2:01 pm
what gear do you already have??
soopachargen
Postby 88.4ageGT » Wed Oct 06, 2010 2:03 pm
2 channel amp
1 sub
4 speakers
AE92 4age GTi
88.4ageGT
Postby soopachargen » Wed Oct 06, 2010 2:04 pm
what sort of amp and sub??
soopachargen
Postby 88.4ageGT » Wed Oct 06, 2010 2:09 pm
amp is lighting audio
is abit old thinking of replacing
and a 12inch fusion sub
AE92 4age GTi
88.4ageGT
Postby 88.4ageGT » Wed Oct 06, 2010 5:07 pm
is this what i use to split the rca
http://www.trademe.co.nz/Browse/Listing ... =321992344
AE92 4age GTi
88.4ageGT
Postby h8wrxs » Sun Oct 24, 2010 5:08 am
tip, buy a new headunit with sub control etc, theyre cheap as nowadays, get a d-class (1 channel) amp, you can run 2 subs off a decent amp
and just run ya speakers off that 2channel amp uve got, just bridge the 2 fronts together and rears together
h8wrxs
