AVS S5 Turbo timer
AVS S5 Turbo timer
Postby GX61 Mark II » Thu Oct 21, 2010 11:03 pm
I have an AVS S5 alarm in my car which has a built in turbo timer. I need to turn off the turbo timer for the toyspeed trackday on Monday.
Does anyone have the programming info for this alarm so I can turn off the turbo timer? (Would like to turn on auto rearm as well at some stage).
Google and the AVS website haven't helped!
Thanks
GX61 Mark II
Postby no_8wire » Fri Oct 22, 2010 12:13 am
XSIV wrote:Anyways, to change turbo timer run times do the following:
Hop in the car and shut the door as well as having boot and bonnet closed
Arm then disarm the alarm
Turn the ignition to ON
Press the boot pop button (left hand button on torch remotes) 16 times, it will beep for each press, if not start again.
Now turn the ignition off, the siren will beep
Press the boot pop button, the alarm will beep out what it is set on
1 beep = 1min, 2 beep = 2.5mins, 3 beeps = 5mins, 4 beeps = 0mins
Press the boot pop button again to cycle through till you have the desired setting
Turn ignition on then off again to exit the mode
no_8wire
Postby no_8wire » Fri Oct 22, 2010 12:16 am
Also for the AutoArm PM XS1V /Brad think he still works for them...
Or phone 09 4768052
no_8wire
Postby GX61 Mark II » Fri Oct 22, 2010 10:10 am
Awesome, Thanks
Will give it a go when I get home tonight.
Cheers!
GX61 Mark II
Postby XS1V » Fri Oct 22, 2010 2:24 pm
Hey
Just a note, the 0 minute setting will still have the engine running on for 10 seconds. This is due to the ignition delay built in to enable the car to start without the immobilisers closing again. The only way to totally stop the turbo timer function is to change the wiring to a normal set up.
Auto arm is as follows:
Hop in the car leaving the door open and have the boot and bonnet closed
Press the boot pop button (left hand button on torch remotes) 4 times, it will beep for each press, if not start again.
Now turn the ignition off, the siren will beep a number of times, one of the beep sequences will be four times. This is the conformation that feature is on :)
Brad
ST205 Group A Rallye #2363
XS1V
Postby spoonza6 » Fri Oct 22, 2010 2:28 pm
sorry to hijack but seems appropriate place to ask the question
whilst trying to set the turbo timer up for different time than the 10sec preset i somehow did the following
1. disarmed the indicator flash when arming/disarming alarm
2. have a non torch remote and car will only unlock using the boot button, wanting it back on the lock/unlock button
3. the panic button doesnt work like it used to
PITA i tell ya
any help with that?
spoonza6
Postby XS1V » Fri Oct 22, 2010 2:37 pm
No worries 8)
Sounds like you have done a few things to yours lol best to give me a call sometime on 4768052 8.30-5.00 weekdays so I can run through on the phone when your with the car :)
Brad
XS1V
Postby spoonza6 » Fri Oct 22, 2010 2:38 pm
bugger will have ta do next time i top up
thanks
yeah its a pretty darn pain in the ass i tell ya
jus glad the thing still arms
spoonza6
Postby XS1V » Fri Oct 22, 2010 2:40 pm
Ever up on the shore?? Pop in and see me, easiest option and I can make sure it is all working as it should be :) Dont mind if you want to pop in after hours also.
Brad
XS1V
