AS200 Altezza
AS200 Altezza
Postby Subway » Mon Feb 07, 2011 9:16 pm
Recently bought an 2002 AS200 Altezza with the factory jap sat nav which I have no intention of using, but I do want to upgrade the headunit and what not.
I understand some of them have a factory amp, I don't want to have to dismantle the dash too often, any way of working out if mine will have the factory amp (meaning ill need the special amp by pass cable)?
Also, I take it the speakers in the doors are 6.5's? (Im putting a set of DLS MS6A's in from my levin)
Also, Im guessing the best place to get the aftermarket dash fascia is trademe? can't seem to find anywhere else.
Also Also, I have the master transponder key, is it possible to get a replacement without paying through the ass at toyota?
Subway
Postby Mr.Phreak » Mon Feb 07, 2011 9:23 pm
Open the glovebox, squeeze the sides in so it can flip right out, the amp is in the gap on the left if you have one.
6.5s will fit.
Best place to pick up a dash fascia is from Nick from North Shore Toyota, after joining the Altezza Club
Mr.Phreak
Postby Subway » Mon Feb 07, 2011 9:26 pm
Mr.Phreak wrote:Open the glovebox, squeeze the sides in so it can flip right out, the amp is in the gap on the left if you have one.
6.5s will fit.
Ok, sweet thanks. The factory headunit is driving me nuts, even with a band expander the lack of ipodness and decent speakers is doing my head in haha.
Subway
Postby Mr.Phreak » Mon Feb 07, 2011 9:39 pm
Mr.Phreak
Postby Emperor » Mon Feb 07, 2011 9:48 pm
What do you mean bypass cable?
After you install your new (aftermarket?) it's the same as if you don't have a factory amp. Wire up headunit, run RCAs for new amp.
Emperor
Postby Mr.Phreak » Mon Feb 07, 2011 9:53 pm
The bypass cable is for just straight headunit swaps.
Although you may want to check the impedance of the rear speakers.
Mr.Phreak
Postby Subway » Mon Feb 07, 2011 10:39 pm
Emperor wrote:What do you mean bypass cable?
Yep, just I wanted to use the rear factory speakers as well. Gahhh, hate running cables grrr
Subway
Postby Emperor » Mon Feb 07, 2011 10:56 pm
Ah I see, so much easier if you had of just said "run a new speaker cable" lol
Emperor
